Discuss
admiral washer
 in
Washer Repair
have a 9 yr old admiral washer. will fill & agitate. when comes time to spin, won't drain. some
Appliance Repair Forum > Appliance Repair Help > Washer Repair » admiral washer
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-31-2007, 04:43 AM
bamadadof2 bamadadof2 is offline
Junior Member
bamadadof2 is on a distinguished road
Exclamation admiral washer
Model Number: aav1000aww   Brand: Admiral   Age: 5 - 10 years
have a 9 yr old admiral washer. will fill & agitate. when comes time to spin, won't drain. some leaking (not very much) on floor. spin timer several times & when it does drain, makes a squeeching sound & won't kick into spin cycle. bad drain pump? bad motor (for spin)? bad timer? please help !
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-31-2007, 05:38 AM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default pump
Leanthe the washer back take the belt off. Then try turning the pump by hand.
  #3 (permalink)
Old 12-31-2007, 07:11 AM
Junior Member
Default in the shop
taken to shop this morning. will find out from them later today (wouldn't you know goes down on holiday...). will find out from shop what they say. may end up buying new since is 9 yrs old. i still think might be timer, pump and/or motor. thanks for help.
  #4 (permalink)
Old 12-31-2007, 11:11 AM
Junior Member
Smile problem solved
call from service guy. tub to water pump had leak in it. that caused some water to leak on floor & also onto belt. the belt would slip & not work properly. may need to check others that have same problem. this one cost me 25.00 for service (dropped off myself & not pay 75.00 for service call to my house) and new hose was 10.00.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
admiral washer margsain Washer Repair 3 09-05-2008 12:35 PM
Admiral Washer Spin Cycle Not Working achetwood Washer Repair 3 12-17-2007 06:44 PM
admiral washer margsain Washer Repair 1 12-03-2007 02:21 PM
Admiral Refrigerator yazooms37342 Refrigerator & Freezer Repair 1 08-10-2007 11:40 AM
admiral capacity plus jcwilson Washer Repair 1 07-30-2007 05:42 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
