Discuss
Washer won't start
 in
Washer Repair
Washer suddenly gives 'LOC' error and 3 beeps...Door lock switch faulty?
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't start
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-30-2007, 09:14 PM
Dos Arroyos Dos Arroyos is offline
Junior Member
Dos Arroyos is on a distinguished road
Default Washer won't start
Model Number: LTF2940ES0   Brand: Frigidaire   Age: 1 - 5 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-31-2007, 04:10 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Take out the lower panel and get the service sheet. There is a test for the door lock switch in there. You will need to pull off the door boot, remove the screws from the door switch, disconnect the connectors and pull out and test. If it fails the test just order a new one.
To put your boot back on you will need to use super glue at spots where you took it off. Good luck and happy new year!
__________________
  #3 (permalink)
Old 12-31-2007, 10:40 AM
Junior Member
Default
Tnx, Rich...Did it and switch failed...Have one on order...Was told this is a pretty popular item...
I live in a rural area and mileage additive is $110 to any work done...Tnx again...
Have a Happy New Year!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool washer motor needs help to start jes999 Washer Repair 3 12-16-2007 09:36 AM
washer won't start teresat6 Washer Repair 0 12-01-2007 08:39 AM
washer want start the spin cycle without help? elizabeth Washer Repair 0 11-23-2007 06:41 PM
Wont start/start switch replaced awilliams197 Dryer Repair 1 09-18-2007 01:33 AM
washer won't start jimzoe@gmail.com Washer Repair 1 09-17-2007 02:51 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
