Discuss
Kenmore elite washer is locked
 in
Washer Repair
I have read dozens of posts here and cannot solve my problem.Washer fills with water but does not agitate,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore elite washer is locked
  #1 (permalink)
Old 12-30-2007, 10:00 PM
PaulRC PaulRC is offline
Junior Member
PaulRC is on a distinguished road
Talking Kenmore elite washer is locked
Model Number: 11020072991   Brand: Kenmore   Age: 5 - 10 years
I have read dozens of posts here and cannot solve my problem.Washer fills with water but does not agitate, spin nor drain. When I try to cycle it to a spin and drain there is a loud clank but no other action except the timer counting down.
I ran through the diagnostics for the panel, motor and cap all are within specs. Also removed pump (is fine) motor (the coupling is fine). I can spin the coupling at the transmission clockwise and the tub turns but I cannot turn the agitator bottom. What should I do next?
Thanks,
Paul
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-31-2007, 06:42 AM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default counter clockwise
turn the shaft on the transmission counter clock wise to see if it turns.
  #3 (permalink)
Old 12-31-2007, 07:58 AM
Junior Member
Default It turns
Yes, it does turn the agitator.
  #4 (permalink)
Old 12-31-2007, 08:56 AM
Junior Member
Default New Info
OK. AS this thing is driving me crazy I decided to hookup the motor outside of the machine and try and cycle the machine so the motor would spin. When I put it on the drain/spin cycle I hear the same loud clunk when I push the lid switch (which I also removed from the cabinet) but the motor does not spin! I checked the capacitor with an OHM meter and it seems fine.
Any thought please.
Paul
  #5 (permalink)
Old 12-31-2007, 09:44 AM
Senior Expert
APP Volunteer
Default Motor
Does the motor turn over easy by hand? seems to me that your motor is locking up. If you hear the clunk with the motor off the machine.
  #6 (permalink)
Old 12-31-2007, 11:05 AM
Junior Member
Default Started over
I went back and started from the beginning. After redoing the panel diagnostics and running tests on the agitation cycles as per the troubleshooting guide I discover a 0 voltage reading on the panel P7 and P9 pins so apparently the main circuit board is bad. I ahould have known because the dryer panel also went bad do to a faulty wall socket.
Regards,
Paul
  #7 (permalink)
Old 11-13-2008, 01:37 PM
SChambers SChambers is offline
Junior Member
SChambers is on a distinguished road
Default Same problem - are you there, PaulRC?
Hi - I have just experienced the exact same problem on the same washer - no agitate, spin or drain, and a clunk, like it wants to work. Paul (or anyone else), how did you fix yours - was this a board failure, or was it maybe a gearbox problem? If it's the board, then I might go ahead and get a new board.
Any answers would be greatly appreciated. Thank you.
Steve, Orange County, CA
Email SSS.Chambers@gmail.com
  #8 (permalink)
Old 11-13-2008, 02:08 PM
v2k04 v2k04 is offline
Senior Expert
APP Volunteer
v2k04 is on a distinguished road
Default
nevermind...........
__________________
  #9 (permalink)
Old 11-13-2008, 02:24 PM
Junior Member
Default Catalyst
Yes, it's a Catalyst washer. The clunk sound I mentioned is the normal, rather loud sound that the washer makes when changing functions, like agitate stop, spin start etc. Maybe the solenoid?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
noisy Kenmore elite achrispyfinn Dishwasher Repair 1 04-25-2008 07:18 PM
Opening Up A Kenmore Elite jmatlin Washer Repair 2 01-06-2008 03:49 PM
Kenmore Elite Dryer Karen Lomba Dryer Repair 2 12-31-2007 09:23 AM
Problems with Kenmore Elite kidao35 Dryer Repair 3 11-02-2007 04:33 AM
Kenmore Elite E1 Sensor collins66 Dryer Repair 3 10-05-2007 02:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
