| » Old Kenmore Agitation Issues |
Model Number: 82172110 Brand: Kenmore Age: Less than 1 year
Both the top and bottom part of the agitator don't have enough power to agitate clothes anymore. The agitator still goes back and forth a little bit and will look as those its working properly if the the washer is empty. The washer spins fills/drains properly. I took the center cap off the agitator and the shoes(dogs) appear to be in good condition. I can't get the agitator out of the washer going by any of the videos/directions I have seen posted though. When I hold the bottom part of the agitator still the bolt will spin in place. Any suggestions on what could be wrong or how to get the agitator out would be appreciated. This thing is from the late 70's so maybe retiring it won't be a bad option, it just seemed to be going strong until yesterday. The matching dryer hasn't had any problems. Kenmore 11082172110
I finally figured out how to get the agitator off, the washer had to mechanically be in the correct cycle for the bolt to loosen. This also made me notice that the problem was that the bolt had come loose on it's own. Tightened the bolt up and it seems to work for a little until the bolt loosens it's self again. Any thoughts on keeping the bolt on top the agitator from loosening itself? It seems kinda crazy that that it's just a rubber washer held down by a bolt that transfers all the power. I'm going to try getting a new bolt and washer and see if that helps. Any downside to putting a ton of torque on that bolt?
Nothing sticks up on the rod past the shaft, the bolt seems to be the only thing that transfers the power. It doesn't even look like there could have been anything that broke off. The plastic cam has splines on it that transfer power to the bottom part of the agitator and they are in perfect condition. The shoes in the cam that transfer power to the top part also look perfect. The top part of the cam is in pretty bad condition now since I tighten the bolt down between each load. The rubber washer is gone (split apart) and I'm using a metal one at this point. I'm going to replace the cam and bolt as soon as I get them in, but I'm worried about the threads in the rod at this point. I'm going to put loctite or some adhesive on the new bolt.
This seems like a GE washer. Can't tell as you are missing the prefix numbers in front of the model # If the bottom of the agitator mates with a plastic drive block, that is the part that is stripped out
__________________
Full number is 110-82172110, only text on the top is Kenmore Heavy Duty Plus. It's belt driven. Thanks for taking the time to help. http://i.imgur.com/wkqFj.jpg picture of the cam inside the top of the agitator, black stuff is pretty much all grease, you can see one of the orange shoes engaged at the bottom
| Display Modes | |
| Kenmore Washer Agitation Problem | garyz | Washer Repair | 1 | 12-09-2009 06:57 AM |
| Maytag Washer Agitation Issues | bryon.mack | Washer Repair | 3 | 11-22-2009 12:09 PM |
| Kenmore Washer Banging During Agitation | scott123 | Washer Repair | 3 | 06-09-2009 01:53 PM |
| Kenmore washer leaking during agitation | TK5028 | Washer Repair | 1 | 01-11-2009 02:37 PM |
| Kenmore 90 Series - No agitation | jastek | Washer Repair | 3 | 02-20-2008 02:54 PM |
