Motor clp is good will not spin.Altho motor runs.I have seen differing views as to repair as far as clutch removal goes. After tilting machine back.Can just the 3 bottom bolts be removed and just take the 1 bolt that holds agitator down off? Or do you need to pull basket off and remove spanner block also?
