celtsone
#1 Posted : Monday, June 29, 2009 2:54:41 PM(UTC)
celtsone
Have Water Pouring Out Of Hose Flood When Machine Filled All The Way Up. See Part Called Gasket Flood Head. Do You Think I Need To Replace This And What Purpose Does It Have?
applianceman
#2 Posted : Monday, June 29, 2009 4:51:27 PM(UTC)
applianceman
It sounds like it’s a possibility the brakes are not working. Take the front off the washer and watch it during the wash cycle. If during the wash cycle the spin basket (inter tub) spins the brakes have failed. Also if the washer is spinning at full speed and you open the lid and the spin basket doesn’t stop quickly the brakes are bad.
If the brakes are not the problem it may be running to much water in the tub causing it to overflow. Also if there is a lot of suds in the tub water can leak out of the overflow in this case either cut down on the detergent or change detergent brands.
Clothes Washer Repair Guide
Extension hose for GE washing machine GFW850SPNRS (Washer Repair)
by Guest 3/17/2023 9:53:53 PM(UTC)
GE Washing machine water level problem (Washer Repair)
by Guest 12/3/2022 12:53:02 AM(UTC)
GE washing machine leaking help (Washer Repair)
by HotCarl919 6/18/2022 8:12:16 AM(UTC)
GE Washing Machine no lights and will not turn on sometimes (Washer Repair)
by Denver714 3/11/2021 6:58:31 AM(UTC)
Before you replace that GE washing machine control board... (Washer Repair)
by GEfixerupper 10/11/2020 6:25:53 PM(UTC)
GE washing machine wash cycle issue (Washer Repair)
by MrLuke 4/23/2020 11:00:59 AM(UTC)
GE washing machine power goes on and off (Washer Repair)
by momage333 3/29/2020 6:03:57 AM(UTC)
GE Washing machine deep fill (Washer Repair)
by tech07 5/12/2019 5:10:57 AM(UTC)
Help on GE washing machine (model WBB4500E1WW) (Washer Repair)
by charley807 2/5/2019 9:26:42 AM(UTC)
GE Washing Machine Drips When Off (Washer Repair)
by kevin1boyd 5/7/2017 5:48:33 AM(UTC)
GE Washing Machine freezes and locks up (Washer Repair)
by Swilly 8/24/2016 1:39:40 PM(UTC)
GE washing machine wont drain or spin but agitates (Washer Repair)
by Billybrokege 5/14/2015 2:26:58 PM(UTC)
ge washing machine help (Washer Repair)
by dnpro02 3/19/2015 7:57:02 PM(UTC)
GE Washing Machine Making Crazy Noise and Electrical Smell (Washer Repair)
by TripleDigitRide 6/21/2014 8:05:46 AM(UTC)
GE Washing machine is overflowing on super setting only (Washer Repair)
by Ctomanec 3/29/2014 9:53:09 AM(UTC)
