Discuss
tub r&r
 in
Washer Repair
My Maytag top loader was leaking, I diagnosed bad tub seal, got the correct part & spanner wrench, r&
Appliance Repair Forum > Appliance Repair Help > Washer Repair » tub r&r
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-30-2007, 05:04 PM
dkarten dkarten is offline
Junior Member
dkarten is on a distinguished road
Default tub r&r
Model Number: la612   Brand: Maytag   Age: More than 10 years
My Maytag top loader was leaking, I diagnosed bad tub seal, got the correct part & spanner wrench, r&r the old seal, on reassembly I can't seem to get tub installed properly, have done several loads, no leak, but vibration/contact tub seems to not be aligned, installed incorrectly? any advice?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-31-2007, 04:43 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Make sure each tub support spring is the same length as before. Also, check the feet to make sure they are all touching the floor.
__________________
  #3 (permalink)
Old 12-31-2007, 06:31 AM
Junior Member
Default tub R&R
springs were not touched,spanner nut rests directly on tub, which is hard to center, I can see it turn unevenly, the new seal was updated,as far as I know I reassembled correct, does anyone have a parts schematic?
  #4 (permalink)
Old 01-01-2008, 01:34 PM
Senior Expert
APP Volunteer
Default
You need to loosen the tub nut and re-adjust tub to center it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
