| » Maytag front load agitates, no spin |
Model Number: MAH4000AWW Brand: Maytag Age: 5 - 10 years
Maytag front load MAH4000AWW. Runs through all the cycles agitates and drains but will not spin. When it's time for the final spin I can hear a humm ( I assume that's the pump) and that's it. If you have any Ideas for a fix, great, and if it involves lifting up the top cover of the machine or any other tricky stuff, please include instructions for that too! Thanks, Michael
Hi Michael
You have one of the most troubled washers that anyone ever made, which you probably realize by now. Rather than try to take you through all the possible areas that cause your problem I would suggest the following. 1. Look through the service manual, particularly the section on not spinning on pages 3-6 to 3-7. Here it is. http://www.servicematters.com/maytag...s/16010061.pdf Note that it will also have instructions for you to open the machine when you need to. 2. Use the search function to look at all the other posts on the MAH 4000 on this site, with particular attention to the discussion of failure of wax motors and the subsequent failure of the control board. If you have not replaced your wax motors you will need to. 3. Look at the service library from Maytag and look specifically at the items involving the motor/motor control conversion kit and the resistor failing. http://www.servicematters.com/maytag...tml/index.html All this should give you a good starting point if you want to diagnose and fix this problem yourself. The door lock mechanism is a good suspect here, along with the wax motors if they are original. Good luck, keep us updated.
__________________
Quote:
Fantastic, glad it worked out for you, and really glad you had replaced the wax motors and board.
As I said, it is a troubled machine but yours should last a good long time as long as "Slammin John" does not live up to his name. Thanks also for updating us, now we have another diagnostic to consider on the Neptunes
__________________
| Display Modes | |
| Maytag Performa no spin, agitates instead | jstiel | Washer Repair | 10 | 02-07-2010 08:16 PM |
| Maytag Front Load Washer | dannyrwalls@yahoo.com | Washer Repair | 1 | 11-14-2009 05:46 PM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
| Maytag front load washer | gbove | Washer Repair | 1 | 07-09-2009 05:18 PM |
| GE Front load won't spin | lemoncadillac | Washer Repair | 0 | 01-16-2009 03:32 PM |
