| » Ge Washer Want Spin |
How to Reset your GE Washer :
1. Turn the dial like your going to wash a load but do not pull the knob. 2. Unplug the washer from the wall and wait for 30 seconds. 3. Plug the washer back into the wall. 4. Lift the lid 5 times to at least 6 inches high. Open/Close within 15 secs. 5. Pause… You should here a click. If you do not, then repeat 1 – 5 again. 6. Insert a towel or garment into the washer and then pull knob to start the wash cycle. 7. Check the wash cycle to make sure the washer is agitating and spinning during its cycle. GE AnswerCenter : 1-800-626-2000 opt 3 - for more information |
| Display Modes | |
| Whirlpool washer won't spin on rinse cycle or high spin | bry21317 | Washer Repair | 10 | 05-24-2011 12:25 PM |
| Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) | cowboys#1 | Washer Repair | 8 | 01-13-2011 10:13 AM |
| Frigidare front load washer will not spin durning final spin cyle | binky8992 | Washer Repair | 2 | 08-19-2009 06:29 PM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
| whirlpool washer won't spin manually or spin | boniam | Washer Repair | 15 | 06-29-2008 07:19 AM |
