Discuss
Maytag Washer leaks on side of drain hose
 in
Washer Repair
How do I remove the lid of the washer? Grab up front push back, then up or pry with a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Washer leaks on side of drain hose
  #1 (permalink)
Old 12-17-2011, 11:34 PM
Junior Member
della is on a distinguished road
Default Maytag Washer leaks on side of drain hose
Model Number: A190   Brand: Maytag   Age: More than 10 years
Grab up front push back, then up or pry with a putty knife, or completely unscrew the control area.
At the present itty bitty droplets (2 max so far) show up during rinse cycle agitation.
Felt outside of drain hose ann inside walls of washer throught round access panels in the back and see no signs of water trace down the right panel (right as you stand in front of the washer).
Getting the top lid open is a challenge and I don't want to mess the enamel on the washer prying it up with a putty knife full force and then find out that's not how you open the top of this machine.
Can you help?
Unable to find info on youtube or the net at large.
Thank you.
Ads By Google
Related Models
Maytag A190 Washer - Top Loading
Maytag A190T Washer - Top Loading
Maytag A1910 Washer - Top Loading
Maytag A200 Washer - Top Loading
Maytag A200S Washer - Top Loading
Maytag A202 Washer - Top Loading
Maytag A202S Washer - Top Loading
Maytag A203 Washer - Top Loading
Maytag A203S Washer - Top Loading
Maytag A206 Washer - Top Loading
Maytag A206S Washer - Top Loading
Maytag A207 Washer - Top Loading
Maytag A207S Washer - Top Loading
Maytag A208 Washer - Top Loading
Maytag A208S Washer - Top Loading
Maytag A209 Washer - Top Loading
Maytag A209S Washer - Top Loading
Maytag A210 Washer - Top Loading
Maytag A210S Washer - Top Loading
Maytag A211 Washer - Top Loading
Maytag A211S Washer - Top Loading
Maytag A211T Washer - Top Loading
Maytag A212 Washer - Top Loading
Maytag A212S Washer - Top Loading
Maytag A212ST Washer - Top Loading
Maytag A212T Washer - Top Loading
Maytag A21CA Washer - Top Loading
Maytag A21CM Washer - Top Loading
Maytag A21CT Washer - Top Loading
Frigidaire A2238C2 Frg(v9) / Room Air Conditioner
Frigidaire A2238D2 Frg(v9) / Room Air Conditioner
Maytag A22CA Washer - Top Loading
Maytag A22CM Washer - Top Loading
Maytag A22CT Washer - Top Loading
Maytag A23CA Washer - Top Loading
Maytag A23CDL Washer - Top Loading
Maytag A23CDW Washer - Top Loading
Maytag A23CSL Washer - Top Loading
Maytag A23CSW Washer - Top Loading
Maytag A23CT Washer - Top Loading
Frigidaire A2438DC2 Frg(v10) / Room Air Conditioner
Frigidaire A2438DD2 Frg(v10) / Room Air Conditioner
Maytag A24CA Washer - Top Loading
Maytag A25CA Washer - Top Loading
Maytag A25CAE Washer - Top Loading
Maytag A25CM Washer - Top Loading
Maytag A25CME Washer - Top Loading
Maytag A25CS Washer - Top Loading
Maytag A25CT Washer - Top Loading
Maytag A26CA Washer - Top Loading
Maytag A26CAE Washer - Top Loading
Maytag A26CD Washer - Top Loading
Maytag A26CDC Washer - Top Loading
Maytag A282 Washer - Top Loading
Maytag A282T Washer - Top Loading
Maytag A283 Washer - Top Loading
Frigidaire A2838C2 Frg(v11) / Room Air Conditioner
Frigidaire A2838D2 Frg(v11) / Room Air Conditioner
Maytag A283T Washer - Top Loading
Maytag A284 Washer - Top Loading
Maytag A284T Washer - Top Loading
General Electric A2B348CKALRA Zoneline
General Electric A2B348DAALRA Zoneline
General Electric A2B348DCALR1 Zoneline
General Electric A2B348DCALRA Zoneline
General Electric A2B348DCANR1 Zoneline
General Electric A2B348DEALRA Zoneline
General Electric A2B348DEASR1 Zoneline
General Electric A2B348DEASRA Zoneline
General Electric A2B348DGALRA Zoneline
General Electric A2B348ENFMRA Zoneline
General Electric A2B349DAALRA Zoneline
General Electric A2B358DAALRA Zoneline
General Electric A2B358DAASRA Zoneline
General Electric A2B358DAESRA Zoneline
General Electric A2B358DCALRA Zoneline
General Electric A2B358DCANRA Zoneline
General Electric A2B358DCASRA Zoneline
General Electric A2B358DCENRA Zoneline
General Electric A2B358DCFSRA Zoneline
General Electric A2B358DEALRA Zoneline
General Electric A2B358DEANRA Zoneline
General Electric A2B358DEASRA Zoneline
General Electric A2B358DEFSRA Zoneline
General Electric A2B358DGALRA Zoneline
General Electric A2B358DGANRA Zoneline
General Electric A2B358DGASRA Zoneline
General Electric A2B358ENASRA Zoneline
General Electric A2B358EPASRA Zoneline
General Electric A2B359DEASRA Zoneline
General Electric A2B359DGASRA Zoneline
General Electric A2B368DAALR1 Zoneline
General Electric A2B368DAASR1 Zoneline
General Electric A2B368DCALR1 Zoneline
General Electric A2B368DCASR1 Zoneline
General Electric A2B368DEAL2R Zoneline
General Electric A2B368DEAL3R Zoneline
General Electric A2B368DEALR1 Zoneline
General Electric A2B368DEASR1 Zoneline
General Electric A2B368DGALR1 Zoneline
General Electric A2B368ESASR1 Zoneline
General Electric A2B369DAASR1 Zoneline
General Electric A2B369DAELR1 Zoneline
General Electric A2B378DAALR1 Zoneline
General Electric A2B378DGALR1 Zoneline
General Electric A2B378DGAS1Y Zoneline
General Electric A2B378ESASR1 Zoneline
General Electric A2B379DEESR1 Zoneline
General Electric A2B383DAALR1 Zoneline
General Electric A2B383DAALR2 Zoneline
General Electric A2B383DAASR1 Zoneline
General Electric A2B383DAASR2 Zoneline
General Electric A2B383DACSR1 Zoneline
General Electric A2B383DACSR2 Zoneline
General Electric A2B383DCALR1 Zoneline
General Electric A2B383DCALR2 Zoneline
General Electric A2B383DEALR1 Zoneline
General Electric A2B383DEALR2 Zoneline
General Electric A2B383ENASR1 Zoneline
General Electric A2B383ENASR2 Zoneline
  #2 (permalink)
Old 12-18-2011, 06:27 AM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
You need to remove the front of the washer first and then the top is bolted down from the inside front corners.
There are two screws towards the bottom of the washer that are hard to see because they are under that funny edge on the front panel. The screws are run in at a angle. Take them two screws out and then left the front panel off from the bottom edge.
1hgqlw5scm.gif 680×940 pixels | Awesome Screenshot
Click on photo to enlarge
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Dishwasher Fill/Drain Hose CBernard Dishwasher Repair 1 10-16-2011 05:10 AM
Replacing Maytag fridge hose drain julia615 Refrigerator & Freezer Repair 0 11-18-2010 01:00 PM
My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? ks_becker Washer Repair 0 08-10-2010 10:25 AM
Maytag Washer Leaks at Drain Cycle ganzhimself Washer Repair 8 06-23-2010 03:09 AM
Maytag Dishwasher Drain Hose Dave Bond Dishwasher Repair 0 05-12-2010 11:52 AM
