Discuss
bearings going bad?
 in
Washer Repair
I have a frontload washer purchased in feb of 03 it makes a terrible sound when drum is going around.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » bearings going bad?
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-30-2007, 09:24 AM
badbikers badbikers is offline
Junior Member
badbikers is on a distinguished road
Default bearings going bad?
Model Number: fwt645rhso   Brand: Frigidaire   Age: 1 - 5 years
I have a frontload washer purchased in feb of 03 it makes a terrible sound when drum is going around. Sounds like something is draging. When I took off the back and top nothing looks wrong. We already replaced the shocks and water pump about a year ago. We also had an Sears tech out and he says with just listening to the drum its the bearings going bad. About a 500 to 600 dollar fix! Is this something that we could do or not even worth it? Any suggestions? Also sears says that its from not using a low sudzing soap and that is why its not covered under the extended warranty. Thanks for some imput.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-30-2007, 02:38 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You can buy the rear shell assembly for about $250 plush shipping. There is a very good article on this at (www.applianceaid.com) ,good luck.
__________________
  #3 (permalink)
Old 12-31-2007, 05:50 AM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default Extended Warranty
It sound to me like the sears tech was trying to get out of work. Call again and ask for a different tech. If that doesn't work try cr. But I'm sure the different tech will order the parts. PS hide your soap and put a jug of h.e. soap on the the shelf.
  #4 (permalink)
Old 05-17-2008, 10:25 AM
Adunc Adunc is offline
Junior Member
Adunc is on a distinguished road
Default Where?
Quote:
I've gone to the website and haven't been able to locate the article.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bearings / seal replace gandra Washer Repair 2 11-03-2007 03:59 PM
Mah3000aww Maytag Neptune/bearings,leak Tinamd Washer Repair 0 10-01-2007 10:30 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
