Discuss
Frigidaire Washer won't spin
 in
Washer Repair
My washer will no longer spin. I've checked the drain pump and tubing. All clear. Pump will start, 5 sec,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire Washer won't spin
  #1 (permalink)
Old 12-16-2011, 09:06 AM
Junior Member
csnow is on a distinguished road
Default Frigidaire Washer won't spin
Model Number: FTF2140ES0   Brand: Frigidaire   Age: 5 - 10 years
My washer will no longer spin. I've checked the drain pump and tubing. All clear. Pump will start, 5 sec, stop and no spin on the spin / drain setting. Can't get the rinse/drain to work either. Shock absorber broke (ordered 2 new) so something could be loose I suppose. Wiring seems ok. Door lock solenoid seems ok. Drum spins fine manually.
Did the diagnostics on the front panel. On the diag tests, anytime it says tumble or spin, that doesn't happen. Error code lights door lock/wash/rinse/final spin/control and the start lights were on 5 times and the start blinked 9 more. Seems to be a 5E code. Not sure what to try next.
Any thoughts? Thanks.
Chris
Ads By Google
Related Models
Frigidaire FTF2140ES0 Frigidaire/washer
Frigidaire FTF2140ES1 Frigidaire/washer
Frigidaire FTF2140ES2 Frigidaire/washer
Frigidaire FTF2140ES3 Frigidaire/washer
Frigidaire FTF2140FS0 Frigidaire/washer
Frigidaire FTF530ES0 Frigidaire/washer
Frigidaire FTF530ES1 Frigidaire/washer
Frigidaire FTF530FS0 Frigidaire/washer
Frigidaire FTF630AS0 Frtld Washer - Frigidaire
Frigidaire FTFB2940FE0 Frigidaire/washer
Frigidaire FTFB4000FS0 Frigidaire/washer
Frigidaire FTFB4000FS1 Frigidaire/washer
Frigidaire FTFB4000GS0 Frigidaire/washer
Frigidaire FTR630AS0 Frtld Washer - Frigidaire
Frigidaire FU017RRW1 Wwh(v2) / Upright Freezer
Frigidaire FU018TRW1 Wwh(v3) / Upright Freezer
Frigidaire FU019ARW5 Wwh(v3) / Upright Freezer
Frigidaire FU054ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU054ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU054ERD3 Wwh(v3) / Upright Freezer
Frigidaire FU054ERW1 Wwh(v4) / Upright Freezer
Frigidaire FU054ERW2 Wwh(v5) / Upright Freezer
Frigidaire FU100JRW1 Wwh(v1) / Upright Freezer
Frigidaire FU100JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU100JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU100JRW4 Wwh(v1) / Upright Freezer
Frigidaire FU100JRW5 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU100LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU100LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW5 Wwh(v2) / Upright Freezer
Frigidaire FU134ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU134ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU134ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU134ERW4 Wwh(v4) / Upright Freezer
Frigidaire FU134JRW1 Wwh(v1) / Upright Freezer
Frigidaire FU134JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU134JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU134JRW4 Wwh(v2) / Upright Freezer
Frigidaire FU134JRW5 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU134LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU134LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU161ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU161ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU161ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU161ERW4 Wwh(v4) / Upright Freezer
Frigidaire FU161ERW5 Wwh(v5) / Upright Freezer
Frigidaire FU161ERW6 Wwh(v6) / Upright Freezer
Frigidaire FU161JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU161JRW2 Wwh(v0) / Upright Freezer
Frigidaire FU161JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU161LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU161LRW3 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU166ERW1 Wwh(v7) / Upright Freezer
Frigidaire FU166ERW2 Wwh(v8) / Upright Freezer
Frigidaire FU166ERW3 Wwh(v9) / Upright Freezer
Frigidaire FU166ERW4 Wwh(v10) / Upright Freezer
Frigidaire FU166HRD1 Wwh(v1) / Upright Freezer
Frigidaire FU166HRD2 Wwh(v2) / Upright Freezer
Frigidaire FU166HRW1 Wwh(v3) / Upright Freezer
Frigidaire FU166HRW2 Wwh(v4) / Upright Freezer
Frigidaire FU166HRW3 Wwh(v5) / Upright Freezer
Frigidaire FU168JRD1 Wwh(v1) / Upright Freezer
Frigidaire FU168JRD2 Wwh(v2) / Upright Freezer
Frigidaire FU168JRD3 Wwh(v1) / Upright Freezer
Frigidaire FU168JRW1 Wwh(v3) / Upright Freezer
Frigidaire FU168JRW2 Wwh(v4) / Upright Freezer
Frigidaire FU168JRW3 Wwh(v2) / Upright Freezer
Frigidaire FU168LRW1 Wwh(v2) / Upright Freezer
Frigidaire FU168LRW2 Wwh(v4) / Upright Freezer
Frigidaire FU169ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU169ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU169ERW1 Wwh(v3) / Upright Freezer
Frigidaire FU169ERW2 Wwh(v4) / Upright Freezer
Frigidaire FU169JRD1 Wwh(v1) / Upright Freezer
Frigidaire FU169JRD2 Wwh(v2) / Upright Freezer
Frigidaire FU169JRD3 Wwh(v4) / Upright Freezer
Frigidaire FU169JRW1 Wwh(v2) / Upright Freezer
Frigidaire FU169JRW2 Wwh(v1) / Upright Freezer
Frigidaire FU169JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU169LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW2 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW3 Wwh(v2) / Upright Freezer
Frigidaire FU169LRW4 Wwh(v3) / Upright Freezer
Frigidaire FU169LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU196ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU196ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU196ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU196JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU196JRW2 Wwh(v4) / Upright Freezer
Frigidaire FU196JRW3 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU196LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU196LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU199ERD1 Wwh(v5) / Upright Freezer
Frigidaire FU199ERD2 Wwh(v6) / Upright Freezer
Frigidaire FU199ERW1 Wwh(v7) / Upright Freezer
Frigidaire FU199ERW2 Wwh(v8) / Upright Freezer
Frigidaire FU199JRD1 Wwh(v0) / Upright Freezer
Frigidaire FU199JRD2 Wwh(v1) / Upright Freezer
Frigidaire FU199JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU199JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU199JRW4 Wwh(v1) / Upright Freezer
Frigidaire FU199LRW1 Wwh(v2) / Upright Freezer
Frigidaire FU199LRW2 Wwh(v3) / Upright Freezer
Frigidaire FU199LRW3 Wwh(v1) / Upright Freezer
Frigidaire FU199LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU199LRW5 Wwh(v1) / Upright Freezer
  #2 (permalink)
Old 12-16-2011, 12:18 PM
Ted/APP Team's Avatar
Expert
Ted/APP Team is on a distinguished road
Default
Hi Chris. This E5E code is Communication problem. Refer to test (13). Test 13:
Communication problem. Check the wiring between the control board and the speed
control board (motor control board) part # [AP3891780].Wiring bad. Correct wiring problem.Wiring good. Replace the control board part # [AP4354654]. If the problem is not corrected, replace the speed control board. I suggest since the shocks are on the way already to look at all the rest of the wires and connections. They may have become loose during the shock issue. Then try the unit and then see if it is OK. Let us know if we can assist. further. Thank You.
Chris
  #3 (permalink)
Old 12-16-2011, 04:53 PM
Junior Member
Default No lights
I did indeed find a loose connection on the speed control board. It was one that connects to the edge of the circuit board. I plugged it in, turned it on and blew something. Must have chosen the wrong connection spot (looks like 2 of them and they are very simliar). Now, no lights, nothing. Does this mean I need a new control board? Do you think the speed control board is ok or am I going to need both? Any chance there is a fuse somewhere that I blew instead of the expensive boards? The lights came on for a second or so and then flashed, noise and off... Thanks.
Chris
  #4 (permalink)
Old 12-16-2011, 05:36 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Did you maybe trip the breaker for the outlet it's plugged into?
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #5 (permalink)
Old 12-18-2011, 07:47 AM
Junior Member
Default No such luck on the ckt breaker
That's not it. Would be nice and easy if it was... I heard popping like capacitors blown. I'll need either just the control board or it and the speed control board...
  #6 (permalink)
Old 12-19-2011, 05:42 AM
Expert
Default
Hi. If you blew the same board as the wire you plugged back into, then yes you will need to start by replacing the speed control board part # [AP3891780]. Thank You.
  #7 (permalink)
Old 12-19-2011, 06:31 AM
Junior Member
Default Speed control or main board
Any way I can figure out which board I need to replace first? If I disconnect the speed control board, should the main panel come up? If not, do I replace the main panel first and then if it doesn't work, the speed control board?
  #8 (permalink)
Old 12-22-2011, 05:19 AM
Expert
Default
Hi Chris. Did you get the spped control board and replace it ? Speed (motor) control board # Part number: AP3891780
. If you unplug it , it will not bring up the fault code denoting the main panel. There are Capacitors on the speed board and if this is the one that blew visually, then this is where to start. Can we assist. you further ? Thank You.
  #9 (permalink)
Old 12-24-2011, 08:22 AM
Junior Member
Default speed control board looks ok
I replaced the main board and the washer lights up again. I saw a spot near j6 which connects to the speed control board where something was definitely blown.
The speed control board looks ok. I wrote down where the 2 connectors were.However, the J#'s on the wiring diagram don't match where they were on the board. The board lists J1 and it was the J5 on the wiring diagram that was connected. That one is right. J1 is right. The problem I have is that across teh top of the board, I have J1, J2, J3. J1 was connected. I have to connect J3 from the wiring diagram to either J2 or J3. Problem was that I already tried J3 and it blew the main board. Do you know if it really belongs in J2? J2 has 5 spots for connectors, J3 has 7. The wiring connector has 5. Seems it goes in J2 but I'm gun shy.
  #10 (permalink)
Old 12-26-2011, 05:50 AM
Expert
Default
Hi. We understand about being gunshy because of being careful not to mention @ the cost. The wiring diagram shows that J-1 has 2 wires. The blue wire goes to the C2-1 connector. The black wire goes to the C2-2 connector. The J3 board connection has the C5-1 red wire. The C5-2 white wire. The C5-3 blk. wire. The C5-4 blue wire. The C5-5 is the orange wire. On the J-5 connector, it has the C7-1 as a green wire.
The C7-3 is a gray wire. The C7-4 wire as a white wire. The C7-5 wire as a brown wire . the C7-6 as a red wire. The C-7-7 as a orange wire. This is a standard wire for front loaders. Have you found /and use the tech. sheet folded in a packet ? It should be in the cabinet either under the top, back cover or inside the front as the envelope is clear plastic and it adheres to the cabinet. Hope this works for you. Keep in touch and let us know how it comes along.Thank You.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire washer won't spin out!! highwaystar Washer Repair 23 12-11-2012 01:33 PM
Frigidaire washer won't spin tsemini Washer Repair 0 02-14-2010 02:12 PM
Frigidaire Washer Won't Spin Out noley99 Washer Repair 1 11-23-2009 09:48 AM
Frigidaire Washer won't spin stein1960 Washer Repair 3 11-22-2009 03:10 PM
Frigidaire Washer Will Not Spin gerharj Washer Repair 1 03-13-2008 04:09 AM
