Got this washer used as non working unit - already replaced the pump and agitator - the top half of the agitator was spinning freely so I opened it up and found the "dogs" were missing so I replaced the agitator. Now the agitate action seems to work fine, except during the agitate cycle the tub gets to going around and around and the clothes don't get agitated like they do when I manually hold the tub from turning....should the tub rotate CCW during agitate or be more or less stationary? thanks
Quote:should the tub rotate CCW during agitate or be more or less stationary? Should be stationary during the agitation cycle.
and how do I fix it if it does rotate?
