| » GE Profile washer disassembly |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: WPSR3090V0WW Brand: GE Age: 5 - 10 years
My washer leaks water from the bottom. I removed the front & top panel, and balance ring. The agitator pulled right off. I am trying to remove the inner basket to get to the tub seal (I watched water slowly drip from the center seal). My question(s) are:
1. How do I remove the inner tub? 2. To remove the inner tub hub, do I remove the hub nut? (it looks like there is a smaller nut or washer inside the hub nut). Since I have the covers off, I would like to replace the tub seal and associated parts. Thanks very much. |
You will need a special spanner wrench to get the nut off. It's a left hand thread so turn the nut clockwise.Lots of times they freeze up on the hub and you have to chisel them off. Good luck, I have one in the junkyard I could never get off even with a cold chisel and a lot of pounding.
__________________
Thanks much, Rich. You're right, it is definitely frozen on. Actually, I did not even need to take off the hub. My whole problem was a worn belt which slipped and let the inner tub turn around when agitating. Purchased a new belt, got it tight, and washer works great. I just have to keep reminding myself --- something I already know very well ---- always look for the simplest solution FIRST......
| Display Modes | |
| GE Profile washer | jkoz6 | Dishwasher Repair | 1 | 12-21-2007 02:32 PM |
| GE Profile won't run | edroffey | Trash Compactor Repair | 0 | 12-13-2007 10:37 AM |
| Upper rack disassembly | flsunshine | Dishwasher Repair | 2 | 12-07-2007 06:24 AM |
| Viking gas cooktop disassembly? | slednerd | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2007 10:58 AM |
| oil leak from under ge profile washer | husker | Washer Repair | 0 | 10-14-2007 12:21 PM |
