Discuss
Whirlpool washer won't spin, drain, or agitate
 in
Washer Repair
I bought an old used whirlpool washer a few months back and it has run fine until today. After filling
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer won't spin, drain, or agitate
  #1 (permalink)
Old 12-14-2011, 04:57 PM
Junior Member
mosierap is on a distinguished road
Default Whirlpool washer won't spin, drain, or agitate
Model Number: LSC8244DQ0   Brand: Whirlpool   Age: 5 - 10 years
I bought an old used whirlpool washer a few months back and it has run fine until today. After filling with water, nothing happens. It acts as if the lid has been left open so I tested the lid switch with a multimeter and found it to be working properly.
When I switch the water level dial, it shoots a bit of water into the barrel, then immediately stops (its already full), so power doesn't seem to be the issue...
Since I got this washer it has always run whether the lid is open or not, which initially led me to suspect the lid switch. Now I'm at a loss...please help!
Related Models
Whirlpool LSC8244DQ0 AUTOMATIC WASHER
Whirlpool LSC8244DZ0 AUTOMATIC WASHER
Whirlpool LSC8244EQ0 WASHER
Whirlpool LSC8244EQ1 WASHER
Whirlpool LSC8244EZ0 WASHER
Whirlpool LSC8244EZ1 WASHER
Whirlpool LSC8245AN0 AUTOMATIC WASHER
Whirlpool LSC8245AQ0 AUTOMATIC WASHER
Whirlpool LSC8245AW0 Washers*
Whirlpool LSC8245BW0 Washers*
Whirlpool LSC9000PW0 AUTOMATIC WASHER
Whirlpool LSC9000PW1 AUTOMATIC WASHER
Whirlpool LSC9000PW2 AUTOMATIC WASHER
Whirlpool LSC9245BN0 AUTOMATIC WASHER
Whirlpool LSC9245BN1 AUTOMATIC WASHER
Whirlpool LSC9245BQ0 AUTOMATIC WASHER
Whirlpool LSC9245BQ1 AUTOMATIC WASHER
Whirlpool LSC9245BW0 AUTOMATIC WASHER
Whirlpool LSC9245BW1 AUTOMATIC WASHER
Whirlpool LSC9245BZ0 AUTOMATIC WASHER
Whirlpool LSC9245BZ1 AUTOMATIC WASHER
Whirlpool LSC9355AG0 AUTOMATIC WASHER
Whirlpool LSC9355AN0 AUTOMATIC WASHER
Whirlpool LSC9355AW0 Washers*
Whirlpool LSC9355BN0 AUTOMATIC WASHER
Whirlpool LSC9355BN1 AUTOMATIC WASHER
Whirlpool LSC9355BQ0 AUTOMATIC WASHER
Whirlpool LSC9355BQ1 AUTOMATIC WASHER
Whirlpool LSC9355BW0 AUTOMATIC WASHER
Whirlpool LSC9355BW1 AUTOMATIC WASHER
Whirlpool LSC9355BZ0 AUTOMATIC WASHER
Whirlpool LSC9355BZ1 AUTOMATIC WASHER
Whirlpool LSC9355DQ0 AUTOMATIC WASHER
Whirlpool LSC9355DZ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ1 DIRECT-DRIVE WASHER
Whirlpool LSC9355EZ0 AUTOMATIC WASHER
Whirlpool LSC9355EZ1 DIRECT-DRIVE WASHER
Admiral LSD2615HEB REF - SXS/I&W
Admiral LSD2615HEW REF - SXS/I&W
Admiral LSD2615HEZ REF - SXS/I&W
Maytag LSE1000 STACKED LAUNDRY- ELE
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-8 STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-C STACKED LAUNDRY- ELE
Jenn-Air LSE2704W STACKED LAUNDRY- ELE
Jenn-Air LSE2704W-8 STACKED LAUNDRY- ELE
Maytag LSE7800 STACKED LAUNDRY- ELE
Maytag LSE7800ACE STACKED LAUNDRY- ELE
Maytag LSE7800ACL STACKED LAUNDRY- ELE
Maytag LSE7800ACW STACKED LAUNDRY- ELE
Maytag LSE7800ADE STACKED LAUNDRY- ELE
Maytag LSE7800ADL STACKED LAUNDRY- ELE
Maytag LSE7800ADW STACKED LAUNDRY- ELE
Maytag LSE7800AEE STACKED LAUNDRY- ELE
Maytag LSE7800AEL STACKED LAUNDRY- ELE
Maytag LSE7800AEW STACKED LAUNDRY- ELE
Admiral LSE7800AGE STACKED LAUNDRY- ELE
Admiral LSE7800AGL STACKED LAUNDRY- ELE
Maytag LSE7804ACE STACKED LAUNDRY- ELE
Maytag LSE7804ACL STACKED LAUNDRY- ELE
Maytag LSE7804ACM STACKED LAUNDRY- ELE
Maytag LSE7804ADE STACKED LAUNDRY- ELE
Maytag LSE7804ADL STACKED LAUNDRY- ELE
Maytag LSE7804ADM STACKED LAUNDRY- ELE
Maytag LSE7804AEE STACKED LAUNDRY- ELE
Admiral LSE7804AGE STACKED LAUNDRY- ELE
Admiral LSE7804AGL STACKED LAUNDRY- ELE
Admiral LSE7804AGM STACKED LAUNDRY- ELE
Maytag LSE7806ACE STACKED LAUNDRY- ELE
Maytag LSE7806ACM STACKED LAUNDRY- ELE
Maytag LSE7806ACQ STACKED LAUNDRY- ELE
Maytag LSE7806ADE STACKED LAUNDRY- ELE
Maytag LSE7806ADM STACKED LAUNDRY- ELE
Maytag LSE7806ADQ STACKED LAUNDRY- ELE
Maytag LSE7806AEE STACKED LAUNDRY- ELE
Maytag LSE7806BCE STACKED LAUNDRY- ELE
Admiral LSE7806GGE STACKED LAUNDRY- ELE
Whirlpool LSE9355BQ0
Whirlpool LSE9355BZ0
Maytag LSE9900 STACKED LAUNDRY- ELE
Maytag LSE9900ACE STACKED LAUNDRY- ELE
Maytag LSE9900ACL STACKED LAUNDRY- ELE
Maytag LSE9900ACW STACKED LAUNDRY- ELE
Maytag LSE9900ADE STACKED LAUNDRY- ELE
Maytag LSE9900ADL STACKED LAUNDRY- ELE
Maytag LSE9900ADW STACKED LAUNDRY- ELE
Maytag LSE9900AEE STACKED LAUNDRY- ELE
Maytag LSE9900AEL STACKED LAUNDRY- ELE
Maytag LSE9900AEW STACKED LAUNDRY- ELE
Maytag LSE9900AFL STACKED LAUNDRY- ELE
Maytag LSE9900AFW STACKED LAUNDRY- ELE
Maytag LSE9904ACE STACKED LAUNDRY- ELE
Maytag LSE9904ACL STACKED LAUNDRY- ELE
Maytag LSE9904ACM STACKED LAUNDRY- ELE
Maytag LSE9904ADE STACKED LAUNDRY- ELE
Maytag LSE9904ADL STACKED LAUNDRY- ELE
Maytag LSG1000 STACKED LAUNDRY- GAS
Maytag LSG1000T Stacked Laundry - Gas
Jenn-Air LSG2700W STACKED LAUNDRY- GAS
Jenn-Air LSG2704W STACKED LAUNDRY- GAS
Maytag LSG7800 STACKED LAUNDRY- GAS
Maytag LSG7800AAE STACKED LAUNDRY- GAS
Maytag LSG7800AAL STACKED LAUNDRY- GAS
Maytag LSG7800AAW STACKED LAUNDRY- GAS
Maytag LSG7800ABE STACKED LAUNDRY- GAS
Maytag LSG7800ABL STACKED LAUNDRY- GAS
Maytag LSG7800ABW STACKED LAUNDRY- GAS
Maytag LSG7804AAE STACKED LAUNDRY- GAS
Maytag LSG7804AAL STACKED LAUNDRY- GAS
Maytag LSG7804AAM STACKED LAUNDRY- GAS
Maytag LSG7804ABE STACKED LAUNDRY- GAS
Maytag LSG7804ABL STACKED LAUNDRY- GAS
Maytag LSG7804ABM STACKED LAUNDRY- GAS
Maytag LSG7806AAE STACKED LAUNDRY- GAS
Maytag LSG7806AAM STACKED LAUNDRY- GAS
Maytag LSG7806AAQ STACKED LAUNDRY- GAS
Maytag LSG7806ABE STACKED LAUNDRY- GAS
Maytag LSG7806ABM STACKED LAUNDRY- GAS
  #2 (permalink)
Old 12-14-2011, 05:07 PM
Member
ramblinche81 is on a distinguished road
Default
Digital or mechanical timer system ?
If mechanical rotary timer, your timer might be stuck. Does a different wash cycle work properly ? If it still doesn't work on different wash cycle, it is still your lid switch...did you check it in the unit or did you remove and check ? Sometimes, the switch toggle is bent and doesn't have enough room to fully close and activate the switch.
  #3 (permalink)
Old 12-14-2011, 05:37 PM
Junior Member
Default
It is an old mechanical timer. I removed it and and inspected the wiring and nothing appears scorched or loose. Is there a way to test the timer in isolation?
I removed the switch and tested it with a multimeter. It clicks and closes the circuit when depressed. And after thinking about it I realized it had been working properly prior to today. A faulty lid switch shouldn't prevent agitation, correct? Just spinning and draining.
  #4 (permalink)
Old 12-14-2011, 06:27 PM
Member
Default
It varies by model/year, I don't recall when it became universal for lid to be closed for agitation. So yes, agitation requires lid to close and switch to close as well.
If it fills with water, then stops, it is usually lid switch.
If you can click the timer knob over to another sequence and it still won't function, I am confident it is lid switch. Contacts on control knob don't usually burn on all points.
But it could be the control knob timer motor...if that is the case, you should be able to click it to next steps and it still runs...you should be able to manually advance the knob and if lid switch is good, it will run next sequence.
  #5 (permalink)
Old 12-15-2011, 06:21 AM
Junior Member
Default
Thanks, but I'm pretty sure it isn't the lid switch. I've done continuity tests with a multimeter and the switch performs as it should. I've also tried jumping the plug that the switch connects to, with no success.
After discussing it with my girlfriend, we recalled that the washer, when it was working, used to immediately start to agitate once the water reached the right level, whether the lid was open or not, but during spin cycles opening the lid would stop the washer. This came up because she had been the last one to use the washer and had to twice stop it to adjust an off-balance load during spin.
  #6 (permalink)
Old 12-15-2011, 08:28 AM
Junior Member
Default
So to summarize:
-When engaged on a wash cycle, the washer fills properly, stops filling at the correct level, then nothing.
-The lid switch tests as functional, and the washer currently does not work during a part of the cycle when it previously did work with an open lid. (This tells me the switch is not the culprit).
-I am able to manually advance the timer, and it does not engage agitation, spinning, or draining on any cycle setting. Though it does open the valve to fill the barrel if I engage it on a wash cycle and the water level is low enough. (This tells me the timer itself is not the issue)
Unless someone has a better idea, I am forced to conclude there is a broken connection or short somewhere in the circuit flow between filling and timer engagement. Is this possible, or even make sense?
I'm starting to walk my way through the circuit diagram pasted to the back of the washer, but it's partially rubbed off. Is there one available online for this model?
  #7 (permalink)
Old 12-15-2011, 11:42 AM
Junior Member
Default
Update: I'm working my way through the circuit diagram. Some of the connections I would expect to be dead are reading live at 60V. This includes the timer motor, though it does not appear to be advancing despite the power. I also found that when I manually advance the timer dial the buzzer sounds at the appropriate time.
Is the 60V normal or a sign that there's a voltage drain somewhere? It makes sense to me that 60V might run some components (water inlet valve, buzzer) but not others...
  #8 (permalink)
Old 12-15-2011, 02:24 PM
Junior Member
Default
I finally found the problem. I discovered a blown terminal in the wiring harness that connects to the motor switch. I replaced it, however now there is a loud hum when the motor should be engaging.
  #9 (permalink)
Old 12-15-2011, 05:35 PM
Junior Member
Default
Something in the drive train is seized up, or at least not moving as smoothly as it should. I suspect this is what caused the terminal to blow.
I removed the motor and found it spins fine. There was a fair bit of motor grease on the exterior of the gearcase. I'm thinking that maybe it leaked out of the gearcase or clutch assembly and that's causing the friction? I couldn't figure out how to detach the gearcase from the drive tube, at least while in the upright position, so I decided to call it a day.
Can someone please advise? What part is most likely to seize if the grease leaked out and is it worth trying to disassemble, replace the grease, and reassemble? I've come so far, and I really don't want to have to spring for a new washer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Won't Drain Spin Or Agitate carlous Washer Repair 15 10-08-2011 08:31 PM
Ge washer won't agitate spin or drain Kevin2685 Washer Repair 1 04-19-2011 04:01 PM
whirlpool washer will agitate, but wont spin or drain robert garbacz Washer Repair 5 04-11-2011 07:26 AM
Whirlpool Washer no drain, spin or agitate dstarnik Washer Repair 3 01-30-2011 05:33 AM
Whirlpool Ultimate Care II will not spin, agitate, or drain. BBowman Washer Repair 1 12-21-2009 12:30 PM
