Discuss
machine does not start to agitate unless clothes inside are repositioned
 in
Washer Repair
My wife tells me the machine does not want to start agitating until she moves the clothes around. This has
Appliance Repair Forum > Appliance Repair Help > Washer Repair » machine does not start to agitate unless clothes inside are repositioned
  #1 (permalink)
Old 06-25-2009, 06:39 PM
charleyk charleyk is offline
Junior Member
charleyk is on a distinguished road
Default machine does not start to agitate unless clothes inside are repositioned
Model Number: 110.20912991   Brand: Kenmore   Age: 5 - 10 years
My wife tells me the machine does not want to start agitating until she moves the clothes around. This has happened on the last 4 loads so I'm starting to believe her. I saw it once. The machine fills fine and is ready to start the washing cycle when it happens After she moves moves the clothes around and closes the lid, the rest of the cycle is fine. She says she might do this once or more than once to get it going.
Any ideas on where to troubleshoot?
Thanks,
charleyk
Related Models
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
  #2 (permalink)
Old 06-26-2009, 08:12 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You might have an intermittant lid switch if the motor fails to start whenever this happens.
__________________
  #3 (permalink)
Old 06-26-2009, 08:57 AM
Junior Member
Default
So are you saying that you think it is actually the opening and closing of the lid that is starting the motor? If so, is there any easy way to test this the next time it happens?
  #4 (permalink)
Old 06-26-2009, 09:03 AM
Senior Expert
APP Volunteer
Default
Post the symtoms the next time it fails, hard to tell what it is really.
__________________
  #5 (permalink)
Old 06-27-2009, 08:12 PM
Junior Member
Default
OK. It happened again. Now it's making more sense. It is when the machine gets to the spin cycles that it stops working. Works fine while filling and agitating. I found that when it stops, my just pushing down on the lid with a little pressure right above the lid switch,gets it going. I think it was a coincidence that my wife repositioned the clothes and it worked. It was probably the opening and closing of the lid.
So, it looks like I will replace the lid switch. Is there any way the problem is with plastic pin that goes into the switch? Also, is there anything special I need to know to replace the switch? It looks like 2 screws is all that holds it.
  #6 (permalink)
Old 06-28-2009, 05:13 AM
Senior Expert
APP Volunteer
Default
Very easy to put it in, just two screws and a 5/15 ground screw. You will need to call this parts site to order it.
__________________
  #7 (permalink)
Old 06-28-2009, 07:58 AM
Junior Member
Default
Do I need to remove the cabinet to get the switch out?
  #8 (permalink)
Old 06-28-2009, 09:45 AM
Senior Expert
APP Volunteer
Default
Yes, remove the control panel screws, tilt it back and remove the ripply clamps and the lid switch socket, then tilt outer cabinet forward.
__________________
  #9 (permalink)
Old 06-28-2009, 02:57 PM
Junior Member
Default
Just for the heck of it, I tried something today and I think it worked. Just not exactly sure if it will last. Seeing that if I push down on the lid above the switch gets the machine going, I removed the rubber bumper from the lid switch pin. Then I ground (actually sanded on a belt sander) just a hair off the bumper. about 1/16 maybe. i reinstalled the bumper and it looks like that worked.
Do you think i'm just prolonging the inevitable?
  #10 (permalink)
Old 06-28-2009, 04:14 PM
Senior Expert
APP Volunteer
Default
These switches wear out and eventually will break. Take the screws out and examine it, you might find the switch housing is falling apart.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't start, inside light won't come on StaceyLee Dryer Repair 5 06-15-2009 07:19 PM
Washer Won't Agitate To Wash Clothes ksmaciejewski Washer Repair 4 06-07-2009 07:53 PM
Dirty Inside Tub And Wet Clothes troy123 Washer Repair 1 05-01-2009 08:24 PM
Kenmore will agitate but not spin (findings inside) azimuth Washer Repair 6 06-20-2008 07:50 PM
GE washing machine...clothes stuck! kaslonancy Washer Repair 1 02-22-2008 04:05 PM
