Discuss
Removal of Upper Bearing and Seal Housing
 in
Washer Repair
I will be replacing the Transmission in my Maytag Atlantis washer, which includes a step where the Upper Bearing and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Removal of Upper Bearing and Seal Housing
  #1 (permalink)
Old 12-13-2011, 11:59 AM
Junior Member
schwartz is on a distinguished road
Default Removal of Upper Bearing and Seal Housing
Model Number: MAV6057AWW   Brand: Maytag   Age: More than 10 years
I will be replacing the Transmission in my Maytag Atlantis washer, which includes a step where the Upper Bearing and Seal Housing Assembly must be removed (slid up) from the upper transmission shaft while the Housing Assembly is still attached to the metal Tub Support beneath it. At this point the transmission shaft is clear above the Housing Assembly, the tub has been removed from the Tub Support, and the Tub Support has been freed from the Tub Braces. The service manual instructions then say "Lift up on the Bearing and Seal Housing with Tub Support attached" implying that the bearing would simply slide up the shaft for easy removal. This appears to be a fairly simple step, but in my research I have heard it described by some as more difficult than they thought, requiring a great deal of effort and possibly more than one person to slide the bearing up the shaft.
In your experience, should I be concerned about this step, and if so, do you have any suggestions that might make this any easier. I don't want to spend $230 dollars and not be able to complete the job.
Related Models
Maytag MAV6057AWW WASHER, ATLANTIS
Maytag MAV6200AWQ WASHER, ATLANTIS
Maytag MAV6200AWW WASHER, ATLANTIS
Maytag MAV6250AWQ WASHER, ATLANTIS
Maytag MAV6250AWW WASHER, ATLANTIS
Maytag MAV6257AWQ WASHER, ATLANTIS
Maytag MAV6257AWW WASHER, ATLANTIS
Maytag MAV6260AWW WASHER, ATLANTIS
Admiral MAV6300AGW WASHER-TOP LOADING
Maytag MAV6300AWQ WASHER, ATLANTIS
Maytag MAV6300AWW WASHER, ATLANTIS
Admiral MAV6300BGW WASHER-TOP LOADING
Admiral MAV6300CGW WASHER-TOP LOADING
Maytag MAV6357AWW WASHER, ATLANTIS
Maytag MAV6358AWW WASHER, ATLANTIS
Maytag MAV6451AGW WASHER, ATLANTIS
Maytag MAV6451AWQ WASHER, ATLANTIS
Maytag MAV6451AWW WASHER, ATLANTIS
Maytag MAV6457AWW WASHER, ATLANTIS
Maytag MAV6458AWW WASHER, ATLANTIS
Maytag MAV6548AWQ WASHER, ATLANTIS
Maytag MAV6548AWW WASHER, ATLANTIS
Maytag MAV6601AWQ WASHER, ATLANTIS
Maytag MAV6601AWW WASHER, ATLANTIS
Maytag MAV6650AWW WASHER, ATLANTIS
Maytag MAV7000AWQ WASHER, ATLANTIS
Maytag MAV7000AWW WASHER, ATLANTIS
Maytag MAV7057AWQ WASHER, ATLANTIS
Maytag MAV7057AWW WASHER, ATLANTIS
Maytag MAV7200AWQ WASHER, ATLANTIS
Maytag MAV7200AWW WASHER, ATLANTIS
Maytag MAV7257AWQ WASHER, ATLANTIS
Maytag MAV7257AWW WASHER, ATLANTIS
Maytag MAV7258AWQ WASHER, ATLANTIS
Maytag MAV7258AWW WASHER, ATLANTIS
Maytag MAV7260AWW WASHER, ATLANTIS
Maytag MAV7260BWW WASHER, ATLANTIS
Maytag MAV7357AWQ WASHER, ATLANTIS
Maytag MAV7357AWW WASHER, ATLANTIS
Maytag MAV7358AWQ WASHER, ATLANTIS
Maytag MAV7358AWW WASHER, ATLANTIS
Maytag MAV7450AWQ WASHER, ATLANTIS
Maytag MAV7450AWW WASHER, ATLANTIS
Maytag MAV7501EWW WASHER, ATLANTIS
Maytag MAV7504EWW WASHER, ATLANTIS
Maytag MAV7550AWQ WASHER, ATLANTIS
Maytag MAV7550AWW WASHER, ATLANTIS
Maytag MAV7551AWQ WASHER, ATLANTIS
Maytag MAV7551AWW WASHER, ATLANTIS
Maytag MAV7557EWQ WASHER, ATLANTIS
Maytag MAV7557EWW WASHER, ATLANTIS
Maytag MAV7580EWQ WASHER, ATLANTIS
Maytag MAV7580EWW WASHER, ATLANTIS
Admiral MAV7600ACQ WASHER-TOP LOADING
Admiral MAV7600AGW WASHER-TOP LOADING
Maytag MAV7600AWQ WASHER, ATLANTIS
Maytag MAV7600AWW WASHER, ATLANTIS
Admiral MAV7600BGW WASHER-TOP LOADING
Admiral MAV7600CGW WASHER-TOP LOADING
Maytag MAV7650AWQ WASHER, ATLANTIS
Maytag MAV7650AWW WASHER, ATLANTIS
Maytag MAV7657EWQ WASHER, ATLANTIS
Maytag MAV7657EWW WASHER, ATLANTIS
Maytag MAV7700AWQ WASHER, ATLANTIS
Maytag MAV7700AWW WASHER, ATLANTIS
Admiral MAV7750AGW WASHER-TOP LOADING
Admiral MAV7750BGW WASHER-TOP LOADING
Admiral MAV7750CGW WASHER-TOP LOADING
Maytag MAV7757AWQ WASHER, ATLANTIS
Maytag MAV7757AWW WASHER, ATLANTIS
Maytag MAV8000AWQ WASHER, ATLANTIS
Maytag MAV8000AWW WASHER, ATLANTIS
Maytag MAV8057AWQ WASHER, ATLANTIS
Maytag MAV8057AWW WASHER, ATLANTIS
Maytag MAV8260AWQ WASHER, ATLANTIS
Maytag MAV8260AWW WASHER, ATLANTIS
Maytag MAV8500AWQ WASHER, ATLANTIS
Maytag MAV8500AWW WASHER, ATLANTIS
Maytag MAV8551AWQ WASHER, ATLANTIS
Maytag MAV8551AWW WASHER, ATLANTIS
Maytag MAV8557AWQ WASHER, ATLANTIS
Maytag MAV8557AWW WASHER, ATLANTIS
Maytag MAV8600AWQ WASHER, ATLANTIS
Maytag MAV8600AWW WASHER, ATLANTIS
Maytag MAV8601AWQ WASHER, ATLANTIS
Maytag MAV8601AWW WASHER, ATLANTIS
Maytag MAV8757AWQ WASHER, ATLANTIS
Maytag MAV8757AWW WASHER, ATLANTIS
Maytag MAV9501EWQ WASHER, ATLANTIS
Maytag MAV9501EWW WASHER, ATLANTIS
Maytag MAV9504EWQ WASHER, ATLANTIS
Maytag MAV9504EWW WASHER, ATLANTIS
Maytag MAV9557EWQ WASHER, ATLANTIS
Maytag MAV9557EWW WASHER, ATLANTIS
Maytag MAV9600EWQ WASHER, ATLANTIS
Maytag MAV9600EWW WASHER, ATLANTIS
Maytag MAV9657EWQ WASHER, ATLANTIS
Maytag MAV9657EWW WASHER, ATLANTIS
Maytag MAV9750AGW WASHER, ATLANTIS
Maytag MAV9750AWQ WASHER, ATLANTIS
Maytag MAV9750AWW WASHER, ATLANTIS
Maytag MAVT236AWW WASHER-TOP LOADING
Maytag MAVT346AWW WASHER-TOP LOADING
Maytag MAVT446AWW WASHER-TOP LOADING
Maytag MAVT546EWW WASHER-TOP LOADING
Maytag MAVT634AWW WASHER, ATLANTIS
Maytag MAVT734EWW WASHER, ATLANTIS
Maytag MAVT754EWW WASHER, ATLANTIS
Maytag MAVT834AWQ WASHER, ATLANTIS
Maytag MAVT834AWW WASHER, ATLANTIS
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
  #2 (permalink)
Old 12-14-2011, 07:34 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
That bearing is pressed in, so it can be difficult to remove. You are not going to re use it, so it doesn't matter if you damage it, but you must be very careful not to damage or scratch anything on the shaft.
Good luck, this is not an easy job but if you have the service manual you should be able to do it.
__________________
  #3 (permalink)
Old 02-07-2012, 10:38 AM
Junior Member
rexblisard is on a distinguished road
Default
I just did that on a Maytag Atlantis. FIRST. I am no expert. The outer tub can be removed with 4-inner screws and then the out screws on the edge of the tub. This gives more work room and less chance of damaging the outer plastic tub $78. Under the agitator is what appears to be a white nut with plastic fins. This is a seal and the threads are right hand (turn CCW to remove). The nut with 4 holes that the inner tub is bolted to can now be removed (CCW to remove). Then the seal and bearing on mine easily slid off along with the seal. The lower bearing on the transmission (above brake) is pressed on and I had to use a pully puller to remove it. You won't need to worry about it because a new lower bearing comes installed (pressed on) when you get your new transmission. Watch the brake...It has a spring with 200 lb compression held on by 6 screws or it will offer "excitement". I use 2 C-clamps to remove and it was uneventful as I was able to "gradually release the pressure on the spring" and save my $70 dollars for the spring release tool. Hope this helps....Rex
  #4 (permalink)
Old 02-07-2012, 06:04 PM
Senior Expert
APP Volunteer
Default
Thanks Rex, that is a nice summary, and glad you included the warning on the brake spring.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sump Housing Removal RSpades Dishwasher Repair 0 06-26-2011 10:43 AM
bearing on rear housing jdecker Washer Repair 1 11-18-2009 05:35 PM
Repairing metal hub/housing for bearing water seal crystal368 Washer Repair 1 10-21-2009 01:08 PM
Seal From Cooktop to Housing Dagmar Oven Repair (including Ranges and Cooktops) 0 06-24-2009 10:53 AM
Attaching seal to blower housing sadiehack Dryer Repair 1 03-05-2009 01:50 PM
