Does someone have an easy way to change the brushes? I'm having a problem getting the spring into the holder to lock the brass connector into place.
:mad:
Hi Luci
I am afraid the reason no one has responded is that those on this forum have very little experiece with Bosch, at least I do not. If you search Bosch here you will find very little, for that reason.
Sorry about your problem, and I am going to suggest you search for another forum and see if they can help you out.
Good luck, sorry we could not be more responsive.
