| » Some water remains after cycle is complete |
Model Number: MAH4000AAW Brand: Maytag Age: 5 - 10 years
After my washer completes any wash cycle, I can turn the drum and still hear water sloshing around inside. Does this mean I have a problem with my washer and if so does anyone have recommendations for fixing it?
Thanks, Tracey in Arizona Related Models |
Unless you can see water in the spinner, AND your clothes come out WET, what you're probably hearing when you rotate the spinner is the liquid inside the balance ring. It's there to counter vibration due to the imperfect balance of the spinning load. You may also check the operation of your pump. Sometimes it can be obstructed, preventing a full extraction of the water. I have found coins on the "flapper" check valve causing the problem.
__________________
Nemo malus felix Last edited by magician59 : 06-25-2009 at 08:11 AM. |
You can access the pump from the rear panel. Once you remove the panel (four screws), you'll see the pump just to the left of the tub. Better be ready for quite a bit of water as you disconnect the hoses. If you have pinch-off pliers, they really come in handy. As an alternative, I grab a bunch of towels to keep the mess at a minimum.
__________________
Nemo malus felix |
| Display Modes | |
| bosch dishwasher won't complete cycle dumped water on floor | jimkaren | Dishwasher Repair | 2 | 12-01-2008 10:38 PM |
| Ice Build-up, Defrost heater warms but water remains | sicknick | Refrigerator & Freezer Repair | 1 | 10-22-2008 05:27 PM |
| Water remain when cycle complete | phuoctraniqic | Washer Repair | 2 | 08-01-2008 11:05 AM |
| Still wet after cycle complete | Chris L | Washer Repair | 11 | 02-15-2008 11:50 AM |
| Post Cleaning Cycle Door Remains Locked | khubers | Oven Repair (including Ranges and Cooktops) | 5 | 12-24-2007 05:09 PM |
