Discuss
Whirlpool Duet F11 and F-DL Codes
 in
Washer Repair
I am frustrated with my washing machine! I am getting the F-11 and F-DL codes which I understand
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet F11 and F-DL Codes
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-29-2007, 12:57 AM
jjriggs jjriggs is offline
Junior Member
jjriggs is on a distinguished road
Angry Whirlpool Duet F11 and F-DL Codes
Brand: Whirlpool   Age: 1 - 5 years
I am frustrated with my washing machine! I am getting the F-11 and F-DL codes which I understand to mean that there is possibly a communication error or a door lock error. What do I need to replace? What part numbers do I need and how do I determine which problem I have? Any help would be greatly appreciated, I'm worried that it's going to quit completely!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-29-2007, 02:13 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull off the front bottom panel and check your service sheet to verify error codes. You probably have a bad door switch. Download the service manual I put into this site and follow directions to test switch.
__________________
  #3 (permalink)
Old 12-29-2007, 05:47 AM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
these error codes are not specific FDL can mean door latch failure .it can also mean the ccu board has failed also F11 can mean mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor. if you do not know how to diagnose with out error code you may end up buying wrong part. sometimes doorlatch is not problem central control board CCU is
__________________
  #4 (permalink)
Old 12-29-2007, 05:53 AM
Senior Expert
APP Volunteer
Default
can you manage to lock +unlock door buy shutting off machine and starting over .does it run for a while then shut down / if you shut of machine will door unlock .if so ccu board could be problem
__________________
  #5 (permalink)
Old 12-29-2007, 06:05 AM
Senior Expert
APP Volunteer
Default
Well said Mr fixitall. I go with the most probable failure, however without a meter
diagnosing this will be almost impossible.
__________________
  #6 (permalink)
Old 12-29-2007, 10:25 AM
CAT88 CAT88 is offline
Junior Member
CAT88 is on a distinguished road
Default fdl error codes
Hi, I"ve been though this all year long with all the fdl, door lock, f11 error codes ect.I have had the top of the washer off at least 20 times. Imagine That on a $1400.00 top of the line product .They are usually caused by loose connectors going to the computer board. Shaking them around sometimes works.They vibrate loose during spinning cycle. I added small amount of solder on all connectors were wire clips on computer board.This worked for a few months. Then the board went all together.Blew out 2 resistors on board.Had to replace The board.The relays are supposed to be undersized To . The odds are that you will eventually have to replace the cpu (computer board).They are around $150.00 on the net. I hope you have a better outcome then me. The computer board in this machine has real problems with it and should be recalled.I got the sears smart agreement for $270.00 because I didn"t want to pay $150.00 for a new board and have that not be the problem. Most if not all places will not refund your money on electrical parts.Sears guarrentees to fix it or give you a $500.00 in store credit.It ended up being the cpu board with labor it was $410.00. And we still have a 1 year full warranty under this plan if anything else fails again.Happy new years Craig
  #7 (permalink)
Old 12-30-2007, 03:08 PM
Junior Member
Default
Thank you for your reply. After checking the connections in the troubleshooting manual the display on the front of the machine is showing "Control Locked" and the machine won't do anything. The "Control Lock" light will not go off and the washing machine will not start. Any suggestions?
  #8 (permalink)
Old 12-30-2007, 05:25 PM
Junior Member
Default error codes
Hi. Google search (Kenmore elite he4t self diagnostic test mode how to) It will come up in the epinion section. It will explain the steps that sears uses to self diagnose the machine. Good luck Craig
  #9 (permalink)
Old 12-30-2007, 06:39 PM
Senior Expert
APP Volunteer
Default
have you tried pushing cancel /pause button twice to see if it pumps out, wait till it completes cycle on it own +then start over /will door lock ? will it wash ?will it unlock? does it do nothing ?
__________________
  #10 (permalink)
Old 12-31-2007, 04:37 AM
Senior Expert
APP Volunteer
Default
Sometimes vibration will shake loose a connector or a connector pin. Just check all of them.
Also, others have pried loose the relay tops on the control board, cleaned the contacts, glued back the tops, and found the washer worked fine.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Parts Admin / APP Team Washer Repair 8 06-17-2008 08:11 AM
whirlpool duet washer donnie Washer Repair 4 12-31-2007 04:41 AM
Whirlpool washer Duet job aid richappy General Talk 0 12-28-2007 03:26 AM
error codes on whirlpool duet sport Thad Steele Washer Repair 1 11-02-2007 02:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
