Discuss
Whirlpool Duet F11 and F-DL Codes
 in
Washer Repair
Originally Posted by richappy Sometimes vibration will shake loose a connector or a connector pin. Just check all of them.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet F11 and F-DL Codes
  #41 (permalink)
Old 03-11-2012, 10:35 PM
Junior Member
married52299 is on a distinguished road
Default Reply to all of the threads that have door latch problems!!!
Quote:
Also, others have pried loose the relay tops on the control board, cleaned the contacts, glued back the tops, and found the washer worked fine.
Try and reply to all threads with door latch problems with this solution!!! I may have bought a door latch assembly by mistake. But I may have avoided making a bigger mistake by buying a control module if it weren't for your post. When I checked the connections, I found a loose connection. Works fine now. Thank you very much!!!
  #42 (permalink)
Old 03-12-2012, 01:24 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Thank's for the feedback.
__________________
  #43 (permalink)
Old 03-28-2012, 09:39 AM
LDV LDV is offline
Junior Member
LDV is on a distinguished road
Angry Kenmore washer F1 error
Well, the problem still continues as I'm right now paying $345 to get my washer fixed. Apparently Sears doesn't care about the products they are selling. After spending this money, there is only a 3 month warranly on the board.
Shame on Sears with so many people complaing about this. Will not buy an applicance from them again.
  #44 (permalink)
Old 04-13-2012, 11:23 AM
Junior Member
flyingtiger162 is on a distinguished road
Default Had F11 code on my washer
Had F11 error code on my washer for about last 6 months. Checked all connections now all I get is --- dashed lines and washer will not operated
  #45 (permalink)
Old 04-14-2012, 12:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the washer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #46 (permalink)
Old 06-28-2012, 10:26 PM
Junior Member
lbodden is on a distinguished road
Default F11 code on Duet washer GHW9400PW0
After 6 years of flawless service I'm now getting F11 code. Washer starts to fill and after a few seconds the code appears. Door seems to latch okay but tub does not start to turn. Is there any way to narrow down the F11 code? I've already taken the top off and checked for loose connections but have not opened the CCU cover as yet. I live in the Cayman Islands where parts are not cheap, are often not in stock, and are usually not returnable. I'm an advanced do-it-yourselfer and am willing to get my hands dirty. I have a soldering iron and supplies if re-soldering connections is worth a try. Any suggestions would be much appreciated.
  #47 (permalink)
Old 06-29-2012, 04:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
You may want to review the solutions offered by maxd (page 2), savage26 (page 3) and daabs (page 4).
__________________
  #48 (permalink)
Old 06-30-2012, 11:50 AM
Junior Member
Default
Well, as fate would have it, my sister's Duet washer died this week with a drum/tub issue and I was able to scavenge it for parts. As luck would have it, her CCU board was the same as mine so I swapped it out and now my washer works. I may try to replace all the relays on my old CCU board and see if I can get it to work again. Of course I now have a lot of other spare parts, all of which are in excellent condition. Thanks for all the tips and info from other users in this forum.
  #49 (permalink)
Old 07-08-2012, 09:49 PM
Junior Member
JRH13 is on a distinguished road
Angry F11 misery
I have a Whirlpool Duet model GHW9150PW4 washer that consistantly throws the F11 code, I tried the "fix" resoldering, and all that, to no prevail. I have "fixed" a Kenmore and another Whirlpool using the methods. this ones being a pain. I broke down and ordered a new CCU (8182695) from Sears ($152), installed it and absolutly no change in operation. Ran the self test gets to C:01 and faults F11. in rinse spin setting it will run water then F11, Drain spin drains and F11. Question is whats the next step, wiring harness? MCU? Motor? other than the diagnostic self test is there a way to test MCU and the motor? have not seen any other codes other than the F11.
  #50 (permalink)
Old 07-09-2012, 06:06 AM
Junior Member
Default
I'm no expert and was lucky to get the CCU to fix my washer at no cost from my sister's broken washer. I hope you are able to return the part to Sears. If you have checked for loose connections, I would guess the MCU is next. It sucks to have to spend so much money on parts without being able to be absolutely sure of the part that's needed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Washer error codes F11 and DL tka1121 Washer Repair 2 02-18-2014 04:47 PM
error codes on whirlpool duet sport Thad Steele Washer Repair 4 05-09-2011 09:01 PM
Whirlpool gas range error codes Dan Wilshire Oven Repair (including Ranges and Cooktops) 1 07-08-2009 10:31 AM
Error Codes Whirlpool Oven brummel Oven Repair (including Ranges and Cooktops) 0 08-25-2008 12:27 PM
Whirlpool Gold Error Codes YPKenny412 Oven Repair (including Ranges and Cooktops) 0 06-30-2008 02:04 PM
