Discuss
Whirlpool Duet F11 and F-DL Codes
 in
Washer Repair
The F11 and D/L error codes are common to main board problems. We have had our washer since 2005.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet F11 and F-DL Codes
  #11 (permalink)
Old 02-10-2008, 01:47 PM
maxd maxd is offline
Junior Member
maxd is on a distinguished road
Default Whirlpool Duet F11 and F-DL Codes
The F11 and D/L error codes are common to main board problems. We have had our washer since 2005. It started having D/L problems in 2006. Looking online at that time we learned to jiggle the wire harness. That worked sporadically, until we solved the problem by leaving the washing machine metal top cover off entirely, taking the plastic cover off the main board box, and taping the main board tray to the top rear of the washer. Putting the plastic cover back on the main board box always seemed to cause a problem.
Unwilling to face the ugliness anymore, we wanted to put the cover back on the washing machine two days ago. With everything back in place, we hit a wall of F11 errors. We were way past warranty phase, and badly in need of doing laundry on the weekend. No appliance repair shop or person was available for a fix.
The Motor Control Unit Power connector at the main board was loose, so I decided to see if re-soldering would do the trick. I removed the main board and looked at all solder connections under high power magnifying glass for glaring problems. All four pins of the Motor Control connector had visibly separated from their solder, and there was one pair of pins belonging to the big red resistor in line with the Motor Control connector that had a similar look. In fact there were slight vestiges of solder blowout originating from one of those pins calling attention to it. I re-soldered all those pins and put the board back in place. It worked for awhile, but we started getting D/L errors and F11 errors again. Oddly, they appeared when putting the main board box cover back on.
The main box cover has plastic pegs designed to push down on the main board when snapped on place. I cut the pegs shorter, but that did not help. Looking closer, the pegs are offset inward on the board, and one peg pushes into the black resistor in line with the Line Filter Connector. I figured with all the machine vibration, the black resistor would be affected by the tight tolerance.
I removed the main board again and looked even more closely at the solder around all pins. Sure enough, the solder at one of the black resistor pins showed signs of cracking. The pin could be seen moving up and down slightly with rocking of the resistor above. The Door Lock connector also pins showed signs of fatigue. Soldering all these distressed connections firmly back in place seems to do the trick .... for now. We need to order a replacement board, and keep it handy in case of final board failure.
Getting rid of mildew - Consumer Reports suggests leaving the door slightly ajar on all front loading washers. That has worked for us.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #12 (permalink)
Old 04-18-2008, 07:27 AM
ravisingh ravisingh is offline
Junior Member
ravisingh is on a distinguished road
Default
i did clean but still showing dl or f
  #13 (permalink)
Old 04-29-2008, 06:38 PM
rach267 rach267 is offline
Junior Member
rach267 is on a distinguished road
Default
We have had the same problem for a long time now and our machine is 3 years old. We actually have clothes stuck in the machine getting moldy as we speak and I can't figure out how to get the door unlocked. I would like to try your suggestion, but I don't have the equipment you do and not sure if I'd make it worse. I hate to pay hundreds for a repair main, I'd almost rather just get a cheap washer and get rid of this. Can you just buy a new motherboard? How would you find out where to buy it and the model? Does it go by the machine model number? And do you think it'd have the same problems? I'd be willing to try anything at this point because we've been having to take our laundry other places now and it's getting ridiculous since we spend all that money to buy these machines.
Thanks for the help!
Rachel
  #14 (permalink)
Old 04-30-2008, 02:52 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
the error codes are F/11 SERIAL COMMUNICATION ERROR....Communication between the Central Control Unit (CCU)and the Motor Control Unit (MCU)cannot be sent correctly Potential Causes are#1check wire harness connection to the MCU,the motor,and Central Control Unit(CCU)#2Check the drive system for any worn or failed components #3ReplaceMCU #4ReplaceCCU#5Replace motor#6Replace wire harness ERROR CODE F/dl Door Lock Errow...a door lock error occures if the door cannot be locked.It will try to lock it 6 times before displaying the error. Potential Causes are#1door lock mechanism broken or removed from the door.#2Check door lock/switch assembly#3Check the wire harness connections to the door lock/switch assembly and Central Control Unit(CCU)#4Door lock/switch assembly failure.
__________________
  #15 (permalink)
Old 06-05-2008, 09:57 PM
nelson nelson is offline
Junior Member
nelson is on a distinguished road
Default
I have the same problem, is there a way to fix it?
  #16 (permalink)
Old 08-14-2008, 05:10 PM
roycbarney roycbarney is offline
Junior Member
roycbarney is on a distinguished road
Default
Where will you order the part from and how much is it?
  #17 (permalink)
Old 08-15-2008, 02:46 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
roycbarney,
What is the complete model number of the unit and which part are you looking for?
__________________
Professional appliance repair in Los Angeles, California.
  #18 (permalink)
Old 08-18-2008, 11:31 AM
Junior Member
Default Model
Ghw9400pw0, and thank you so much for responding to my post. I think we should all get together and petition Whirlpool for the replacement parts to fix this problem that it seems all the machines have.
Roy
Quote:
Originally Posted by Gene View Post
roycbarney,
What is the complete model number of the unit and what part are you looking for?
  #19 (permalink)
Old 08-18-2008, 01:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
roycbarney,
What exactly is wrong with your washer and which part are you looking for?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Parts Admin / APP Team Washer Repair 10 10-25-2008 10:08 AM
whirlpool duet washer donnie Washer Repair 4 12-31-2007 05:41 AM
Whirlpool washer Duet job aid richappy General Talk 0 12-28-2007 04:26 AM
error codes on whirlpool duet sport Thad Steele Washer Repair 1 11-02-2007 03:12 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
