Discuss
Installing new thrust bearing kit
 in
Washer Repair
Hello, I am trying to install a new thrust bearing kit for my Maytag washer. I am having some difficulty,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Installing new thrust bearing kit
  #1 (permalink)
Old 06-24-2009, 03:00 PM
davho davho is offline
Junior Member
davho is on a distinguished road
Default Installing new thrust bearing kit
Model Number: mav6000aww   Brand: Maytag   Age: 5 - 10 years
Hello, I am trying to install a new thrust bearing kit for my Maytag washer. I am having some difficulty, and I am worried that I received the wrong part. It seems the assembly is just a little too thick and comes out from the stem just enough that I can't get the retaining clip in.
Am I doing something wrong, or do I have the wrong part? Every site I go to gives me the same part number. Thank you if you have any advice for me.
Related Models
Maytag MAV6000AWW Washer, Atlantis
Maytag MAV6057AWQ Washer, Atlantis
Maytag MAV6057AWW Washer, Atlantis
Maytag MAV6200AWQ Washer, Atlantis
Maytag MAV6200AWW Washer, Atlantis
Maytag MAV6250AWQ Washer, Atlantis
Maytag MAV6250AWW Washer, Atlantis
Maytag MAV6257AWQ Washer, Atlantis
Maytag MAV6257AWW Washer, Atlantis
Maytag MAV6260AWW Washer, Atlantis
International MAV6300AGW Washer - Top Loading
Maytag MAV6300AWQ Washer, Atlantis
Maytag MAV6300AWW Washer, Atlantis
International MAV6300BGW Washer - Top Loading
International MAV6300CGW Washer - Top Loading
Maytag MAV6357AWW Washer, Atlantis
Maytag MAV6358AWW Washer, Atlantis
Maytag MAV6451AGW Washer, Atlantis
Maytag MAV6451AWQ Washer, Atlantis
Maytag MAV6451AWW Washer, Atlantis
Maytag MAV6457AWW Washer, Atlantis
Maytag MAV6458AWW Washer, Atlantis
Maytag MAV6548AWQ Washer, Atlantis
Maytag MAV6548AWW Washer, Atlantis
Maytag MAV6601AWQ Washer, Atlantis
Maytag MAV6601AWW Washer, Atlantis
Maytag MAV6650AWW Washer, Atlantis
Maytag MAV7000AWQ Washer, Atlantis
Maytag MAV7000AWW Washer, Atlantis
Maytag MAV7057AWQ Washer, Atlantis
Maytag MAV7057AWW Washer, Atlantis
Maytag MAV7200AWQ Washer, Atlantis
Maytag MAV7200AWW Washer, Atlantis
Maytag MAV7257AWQ Washer, Atlantis
Maytag MAV7257AWW Washer, Atlantis
Maytag MAV7258AWQ Washer, Atlantis
Maytag MAV7258AWW Washer, Atlantis
Maytag MAV7260AWW Washer, Atlantis
Maytag MAV7260BWW Washer, Atlantis
Maytag MAV7357AWQ Washer, Atlantis
Maytag MAV7357AWW Washer, Atlantis
Maytag MAV7358AWQ Washer, Atlantis
Maytag MAV7358AWW Washer, Atlantis
Maytag MAV7450AWQ Washer, Atlantis
Maytag MAV7450AWW Washer, Atlantis
Maytag MAV7501EWW Washer, Atlantis
Maytag MAV7504EWW Washer, Atlantis
Maytag MAV7550AWQ Washer, Atlantis
Maytag MAV7550AWW Washer, Atlantis
Maytag MAV7551AWQ Washer, Atlantis
Maytag MAV7551AWW Washer, Atlantis
Maytag MAV7557EWQ Washer, Atlantis
Maytag MAV7557EWW Washer, Atlantis
Maytag MAV7580EWQ Washer, Atlantis
Maytag MAV7580EWW Washer, Atlantis
International MAV7600ACQ Washer - Top Loading
International MAV7600AGW Washer - Top Loading
Maytag MAV7600AWQ Washer, Atlantis
Maytag MAV7600AWW Washer, Atlantis
International MAV7600BGW Washer - Top Loading
International MAV7600CGW Washer - Top Loading
Maytag MAV7650AWQ Washer, Atlantis
Maytag MAV7650AWW Washer, Atlantis
Maytag MAV7657EWQ Washer, Atlantis
Maytag MAV7657EWW Washer, Atlantis
Maytag MAV7700AWQ Washer, Atlantis
Maytag MAV7700AWW Washer, Atlantis
International MAV7750AGW Washer - Top Loading
International MAV7750BGW Washer - Top Loading
International MAV7750CGW Washer - Top Loading
Maytag MAV7757AWQ Washer, Atlantis
Maytag MAV7757AWW Washer, Atlantis
Maytag MAV8000AWQ Washer, Atlantis
Maytag MAV8000AWW Washer, Atlantis
Maytag MAV8057AWQ Washer, Atlantis
Maytag MAV8057AWW Washer, Atlantis
Maytag MAV8260AWQ Washer, Atlantis
Maytag MAV8260AWW Washer, Atlantis
Maytag MAV8500AWA Washer, Atlantis
Maytag MAV8500AWQ Washer, Atlantis
Maytag MAV8500AWW Washer, Atlantis
Maytag MAV8551AWQ Washer, Atlantis
Maytag MAV8551AWW Washer, Atlantis
Maytag MAV8557AWQ Washer, Atlantis
Maytag MAV8557AWW Washer, Atlantis
Maytag MAV8600AWQ Washer, Atlantis
Maytag MAV8600AWW Washer, Atlantis
Maytag MAV8601AWQ Washer, Atlantis
Maytag MAV8601AWW Washer, Atlantis
Maytag MAV8757AWQ Washer, Atlantis
Maytag MAV8757AWW Washer, Atlantis
Maytag MAV9501EWQ Washer, Atlantis
Maytag MAV9501EWW Washer, Atlantis
Maytag MAV9504EWQ Washer, Atlantis
Maytag MAV9504EWW Washer, Atlantis
Maytag MAV9557EWQ Washer, Atlantis
Maytag MAV9557EWW Washer, Atlantis
Maytag MAV9600EWQ Washer, Atlantis
Maytag MAV9600EWW Washer, Atlantis
Maytag MAV9657EWQ Washer, Atlantis
Maytag MAV9657EWW Washer, Atlantis
Maytag MAV9750AGW Washer, Atlantis
Maytag MAV9750AWQ Washer, Atlantis
Maytag MAV9750AWW Washer, Atlantis
Maytag MAVT236AWW Washer - Top Loading
Maytag MAVT346AWW Washer - Top Loading
Maytag MAVT446AWW Washer - Top Loading
Maytag MAVT546EWW Washer - Top Loading
Maytag MAVT634AWW Washer, Atlantis
Maytag MAVT734EWW Washer, Atlantis
Maytag MAVT754EWW Washer, Atlantis
Maytag MAVT834AWQ Washer, Atlantis
Maytag MAVT834AWW Washer, Atlantis
Whirlpool MB1110SLQ Microwave Oven 1.1 Cubic Foot
International MB1927PEHB  Ref - Maytag Int'l Bot Mount
International MB1927PEHW  Ref - Maytag Int'l Bot Mount
International MB2216PUAW Ref - Bottom Mounts
International MB2227PEHB  Ref - Maytag Int'l Bot Mount
International MB2227PEHW  Ref - Maytag Int'l Bot Mount
Thermador MB245
  #2 (permalink)
Old 06-25-2009, 08:47 AM
magician59 magician59 is offline
Senior Expert
APP Volunteer
magician59 is on a distinguished road
Default
You should have received a couple of washers with different thicknesses in the repair kit. Try using the thinner one. Also, try to separate a gap large enough to start the clip, using a flat tipped screwdriver. Use extreme caution to protect your hands in this process. Once the clip is started, use a plier to "squeeze it home". Remember that you're wrestling against a spring pressure of about 200psi; Begin with a generous measure of patience.
__________________
Nemo malus felix
Reply
« Spin Cycle | Washer »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Atlantis Maytag Washer -not spinning replaced thrust bearing kit nmarie@cox.net Washer Repair 3 10-23-2008 12:33 PM
Replacing Maytag pulley and thrust washers richappy General Talk 0 07-15-2008 04:07 AM
Agitator repair kit thrust washer grease Imbobman Washer Repair 1 06-03-2008 09:58 AM
Installing drum bearing matthall9815 Dryer Repair 1 03-03-2008 11:00 AM
installing the Assy, main bearing jdouglas14 Washer Repair 4 12-03-2007 06:33 PM
