Discuss
Sears Kenmore Heavy Duty 80 Series Washer
 in
Washer Repair
The tub won't spin. The machine will cycle manually and the motor works fine. The drive coupling from the motor
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Sears Kenmore Heavy Duty 80 Series Washer
  #1 (permalink)
Old 06-24-2009, 09:00 AM
Junior Member
lou agathos is on a distinguished road
Default Sears Kenmore Heavy Duty 80 Series Washer
Model Number: 110.82983120   Brand: Sears   Age: 5 - 10 years
The tub won't spin. The machine will cycle manually and the motor works fine. The drive coupling from the motor has been worn out, torn out and the remainder of it was lying on the floor under the washer. I need a new drive coupling which I will order, but I also need to know the procedure for changing it out. Please help. Thank you. Lou Agathos
Ads By Google
Related Models
Kenmore 110.83679630  ELECTRIC DRYER
Kenmore 110.84832200  ELECTRIC DRYER
Kenmore 110.84832201  ELECTRIC DRYER
Kenmore 110.84834200  ELECTRIC DRYER
Kenmore 110.84834201  ELECTRIC DRYER
Kenmore 110.84836200  ELECTRIC DRYER
Kenmore 110.84836201  ELECTRIC DRYER
Kenmore 110.86015100  ELECTRIC DRYER
Kenmore 110.86015110  ELECTRIC DRYER
Kenmore 110.86015120  ELECTRIC DRYER
Kenmore 110.86030100  ELECTRIC DRYER
Kenmore 110.86030110  ELECTRIC DRYER
Kenmore 110.86030120  ELECTRIC DRYER
Kenmore 110.86070100  ELECTRIC DRYER
Kenmore 110.86070110  ELECTRIC DRYER
Kenmore 110.86405160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86405860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407140  ELECTRIC DRYER
Kenmore 110.86407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.86407840  ELECTRIC DRYER
Kenmore 110.86407860  COMMERCIAL ELECTRIC DRYER
Kenmore 110.87405140  GAS DRYER
Kenmore 110.87405160  COMMERCIAL GAS DRYER
Kenmore 110.87405840  GAS DRYER
Kenmore 110.87405860  COMMERCIAL GAS DRYER
Kenmore 110.87407140  GAS DRYER
Kenmore 110.87407840  GAS DRYER
Kenmore 110.92490100  GAS DRYER
Kenmore 110.92822100  GAS DRYER
Kenmore 110.92822101  GAS DRYER
Kenmore 110.92822102  GAS DRYER
Kenmore 110.92824100  GAS DRYER
Kenmore 110.92824101  GAS DRYER
Kenmore 110.92824102  GAS DRYER
Kenmore 110.92826100  GAS DRYER
Kenmore 110.92826101  GAS DRYER
Kenmore 110.92826102  GAS DRYER
Kenmore 110.92832100  DRYER
Kenmore 110.92834100  DRYER
Kenmore 110.92836100  DRYER
Kenmore 110.94832200  GAS DRYER
Kenmore 110.94832201  GAS DRYER
Kenmore 110.94834200  GAS DRYER
Kenmore 110.94834201  GAS DRYER
Kenmore 110.94836200  GAS DRYER
Kenmore 110.94836201  GAS DRYER
Kenmore 110.96060100  ELECTRIC DRYER
Kenmore 110.96091100  ELECTRIC DRYER
Kenmore 110.96091300  ELECTRIC DRYER
Kenmore 110.96091700  ELECTRIC DRYER
Kenmore 110.96091800  ELECTRIC DRYER
Kenmore 110.96093100  ELECTRIC DRYER
Kenmore 110.96093300  ELECTRIC DRYER
Kenmore 110.96093500  ELECTRIC DRYER
Kenmore 110.96093700  ELECTRIC DRYER
Kenmore 110.96093800  ELECTRIC DRYER
Kenmore 110.96094100  ELECTRIC DRYER
Kenmore 110.96094300  ELECTRIC DRYER
Kenmore 110.96094500  ELECTRIC DRYER
Kenmore 110.96094700  ELECTRIC DRYER
Kenmore 110.96094800  ELECTRIC DRYER
Kenmore 110.96110100  ELECTRIC DRYER
Kenmore 110.96121100  ELECTRIC DRYER
Kenmore 110.96195100  ELECTRIC DRYER
Kenmore 110.96195110  DRYER FEATURE SHEET
Kenmore 110.96407160  COMMERCIAL ELECTRIC DRYER
Kenmore 110.97502120  GAS DRYER-COMMERCIAL
Kenmore 110.97502820  GAS DRYER-COMMERCIAL
Kenmore 110.97565120  GAS DRYER
Kenmore 110.97565220  GAS DRYER
Hoover 1100
Magic Chef 1100PAA Range - F/s Std Gas
Magic Chef 1100PAW Range - F/s Std Gas
Magic Chef 1100PAW-K Range - F/s Std Gas
Magic Chef 1100PAW-KL Range - F/s Std Gas
Magic Chef 1100PAW-L Range - F/s Std Gas
Magic Chef 1100PRA Range - F/s Std Gas
Magic Chef 1100PRA-K Range - F/s Std Gas
Magic Chef 1100PRW Range - F/s Std Gas
Magic Chef 1100PRW-K Range - F/s Std Gas
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Sears 11016502693 AUTOMATIC WASHER
Sears 11016502694 AUTOMATIC WASHER
Sears 11016512691 AUTOMATIC WASHER
Sears 11016512692 AUTOMATIC WASHER
Sears 11016602690 AUTOMATIC WASHER
Sears 11016602691 AUTOMATIC WASHER
Sears 11016602692 AUTOMATIC WASHER
Sears 11016602693 AUTOMATIC WASHER
Sears 11016611690 AUTOMATIC WASHER
Sears 11016611691 AUTOMATIC WASHER
Sears 11016611692 AUTOMATIC WASHER
Sears 11016612690 AUTOMATIC WASHER
Sears 11016612691 AUTOMATIC WASHER
Sears 11016612692 AUTOMATIC WASHER
Sears 11016872691 AUTOMATIC WASHER
Sears 11016872692 AUTOMATIC WASHER
Sears 11016872693 AUTOMATIC WASHER
Sears 11018542890 AUTOMATIC WASHER
Hoover 1102
Kenmore 11020052994 WASHER
Kenmore 11020056991 WASHER
Kenmore 11020056992 WASHER
Kenmore 11020056994 WASHER
Kenmore 11020072990 WASHER
Kenmore 11020072991 WASHER
Kenmore 11020072992 WASHER
Kenmore 11020072993 WASHER
Kenmore 11020092990 WASHER
Kenmore 11020092991 WASHER
Kenmore 11020092992 WASHER
Kenmore 11020092993 WASHER
Kenmore 11020094992 WASHER
Kenmore 11020094993 WASHER
Kenmore 11020096990 WASHER
Kenmore 11020096991 WASHER
Kenmore 11020096992 WASHER
Kenmore 11020096993 WASHER
Kenmore 11020097990 WASHER
  #2 (permalink)
Old 06-24-2009, 09:06 AM
Senior Member
applianceman is on a distinguished road
Default
This page should help you with this Whirlpool Washer Disassembly Guide
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
install snubber- kenmore washer heavy duty 70 cathy7 Washer Repair 1 08-31-2009 12:31 PM
Kenmore 70 Series Heavy Duty Plus Washer meagansmommy Washer Repair 1 07-13-2009 12:48 PM
Kenmore 90 Plus Series Heavy Duty washer Betty Moore Washer Repair 1 04-06-2009 09:47 AM
Kenmore Heavy Duty 70 Series jenna Washer Repair 3 04-29-2008 07:03 PM
Kenmore washer agitates on heavy duty but not on permanent press or normal okey Washer Repair 8 02-15-2008 10:53 AM
