Discuss
Kenmore Not Spinning
 in
Washer Repair
My wash machine has recently had problems where there is a smell of burning rubber and the tub is not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Not Spinning
  #1 (permalink)
Old 12-28-2007, 12:33 PM
SteveOz SteveOz is offline
Junior Member
SteveOz is on a distinguished road
Default Kenmore Not Spinning
Model Number: 70 Series   Brand: Kenmore   Age: 5 - 10 years
My wash machine has recently had problems where there is a smell of burning rubber and the tub is not spinning. There are not issues with draining, agitating, or the timer mechanism, just the spin.
I would guess this is a seal or belt issue but do not have the knowledge to be certain, any help would be appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-28-2007, 12:51 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
In order to provide the most accurate advise I need the complete model number of the washer. You can find it under the lid.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-28-2007, 12:55 PM
Junior Member
Default Model Number
Thanks for your help, the model number is:
SM 9710804-A
  #4 (permalink)
Old 12-28-2007, 12:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The number you posted is the serial number.
The model number should have a 110 prefix and 7 or 8 digits after.
__________________
  #5 (permalink)
Old 12-28-2007, 01:06 PM
Junior Member
Default Sorry
Sorry about that Gene,
The model number is 110.20722990
Thanks again.
  #6 (permalink)
Old 12-28-2007, 01:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would check is the motor drive coupling (#13 on the gear case/motor/pump break down diagram).
You have to remove the cabinet to get the access.
- The part number for the motor drive coupling is AP3963893
Good luck and Happy New year.
__________________
  #7 (permalink)
Old 12-28-2007, 01:35 PM
Junior Member
Default Thanks
Thanks for your help Gene,
The instructions on the site are good but are for a Whirlpool, will they be pretty close to the same. Are there any major differences I need to look out for.
  #8 (permalink)
Old 12-28-2007, 01:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The 110 prefix in the model number means your dryer made by Whirlpool.
__________________
  #9 (permalink)
Old 01-17-2008, 06:59 PM
Junior Member
Default
Hello Gene,
I changed the coupling and am still having the problem. I will explain the problem better for you this time.
When the timer gets to the spin cycle the tub drains but does not spin. If the lid is opened and reclosed the tub starts to spin. This happens again at the second spin cycle.
I also replaced the switch and this did not help either. I am out of ideas and am looking for some more help please. Could this have something to do with the timer, but if it does why would the draining initiate?
Thank you for your help,
Steve
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer not spinning rtzjackson Washer Repair 3 09-13-2008 09:24 AM
not spinning peak_az@yahoo.com Washer Repair 4 01-19-2008 04:49 PM
Kenmore (Whirlpool) washer "bang" noise when spinning dadasmatta Washer Repair 2 12-22-2007 08:34 PM
kenmore washer 110.26852501 spinning intermittently 88ply Washer Repair 1 12-08-2007 04:01 PM
Dryer not spinning cozmo Dryer Repair 2 09-27-2007 09:04 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
