Discuss
Temperature Setting Problem
 in
Washer Repair
Maytag LAT8840BAW temperature setting problem. When set to "COLD COLD" - the water comes out very hot. When set to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Temperature Setting Problem
  #1 (permalink)
Old 06-21-2009, 02:28 PM
Junior Member
jodapr is on a distinguished road
Default Temperature Setting Problem
Model Number: LAT8840BAW   Brand: Maytag   Age: 5 - 10 years
Maytag LAT8840BAW temperature setting problem. When set to "COLD COLD" - the water comes out very hot. When set to "WARM WARM" it comes out warm cold. It has worked fine for years and just started doing this. Thank you.
Ads By Google
Related Models
Maytag LAT8840BAW Washer - Top Loading
Maytag LAT8840BBL Washer - Top Loading
Maytag LAT8840BBW Washer - Top Loading
Maytag LAT8904AAE Washer - Top Loading
Maytag LAT8904AAL Washer - Top Loading
Maytag LAT8904AAM Washer - Top Loading
Maytag LAT9200AAE Washer - Top Loading
Maytag LAT9200AAG Washer - Top Loading
Maytag LAT9200AAL Washer - Top Loading
Maytag LAT9200AAM Washer - Top Loading
Maytag LAT9200AAW Washer - Top Loading
Maytag LAT9200ABE Washer - Top Loading
Maytag LAT9200ABL Washer - Top Loading
Maytag LAT9200ABM Washer - Top Loading
Maytag LAT9200ABW Washer - Top Loading
Maytag LAT9200BAE Washer - Top Loading
Maytag LAT9200BAL Washer - Top Loading
Maytag LAT9200BAM Washer - Top Loading
Maytag LAT9200BAW Washer - Top Loading
Maytag LAT9200BBE Washer - Top Loading
Maytag LAT9200BBL Washer - Top Loading
Maytag LAT9200BBM Washer - Top Loading
Maytag LAT9200BBW Washer - Top Loading
Maytag LAT9200DAG Washer - Top Loading
Maytag LAT9200DAL Washer - Top Loading
Maytag LAT9200DAW Washer - Top Loading
Maytag LAT9200DAX Washer - Top Loading
Maytag LAT9205AAE Washer - Top Loading
Maytag LAT9205AAM Washer - Top Loading
International LAT9205GGE Washer - Top Loading
Maytag LAT9206AAE Washer - Top Loading
Maytag LAT9206AAM Washer - Top Loading
Maytag LAT9206ABE Washer - Top Loading
Maytag LAT9206ABM Washer - Top Loading
Maytag LAT9206BAE Washer - Top Loading
Maytag LAT9206BAM Washer - Top Loading
Maytag LAT9206BAQ Washer - Top Loading
Maytag LAT9206BBE Washer - Top Loading
Maytag LAT9206BBM Washer - Top Loading
Maytag LAT9235AAE Washer - Top Loading
Maytag LAT9235AAM Washer - Top Loading
Maytag LAT9280AAL Washer - Top Loading
Maytag LAT9280AAW Washer - Top Loading
Maytag LAT9280ABL Washer - Top Loading
Maytag LAT9280ABW Washer - Top Loading
Maytag LAT9300AAL Washer - Top Loading
Maytag LAT9300AAW Washer - Top Loading
Maytag LAT9300ABL Washer - Top Loading
Maytag LAT9300ABW Washer - Top Loading
Maytag LAT9304AAE Washer - Top Loading
Maytag LAT9304AAL Washer - Top Loading
Maytag LAT9304AAM Washer - Top Loading
Maytag LAT9304ABE Washer - Top Loading
International LAT9304AGE Washer - Top Loading
International LAT9304AGL Washer - Top Loading
International LAT9304AGM Washer - Top Loading
International LAT9304BGE Washer - Top Loading
Maytag LAT9304DAL Washer - Top Loading
Maytag LAT9304DAM Washer - Top Loading
International LAT9304EGE Washer - Top Loading
International LAT9304GGE Washer - Top Loading
Maytag LAT9306AAE Washer - Top Loading
Maytag LAT9306AAM Washer - Top Loading
Maytag LAT9306ABE Washer - Top Loading
International LAT9306AGE Washer - Top Loading
International LAT9306AKM Washer - Top Loading
International LAT9306AKQ Washer - Top Loading
International LAT9306BGE Washer - Top Loading
International LAT9306DAM Washer - Top Loading
International LAT9306DAQ Washer - Top Loading
International LAT9306EGE Washer - Top Loading
International LAT9306GGE Washer - Top Loading
Maytag LAT9314AAE Washer - Top Loading
Maytag LAT9314AAL Washer - Top Loading
Maytag LAT9314AAM Washer - Top Loading
Maytag LAT9314ABE Washer - Top Loading
Maytag LAT9316AAE Washer - Top Loading
Maytag LAT9316AAM Washer - Top Loading
Maytag LAT9316ABE Washer - Top Loading
Maytag LAT9316ABM Washer - Top Loading
Maytag LAT9334AAE Washer - Top Loading
Maytag LAT9334AAL Washer - Top Loading
Maytag LAT9334AAM Washer - Top Loading
Maytag LAT9334ABE Washer - Top Loading
Maytag LAT9356AAE Washer - Top Loading
Maytag LAT9356AAM Washer - Top Loading
Maytag LAT9356AAQ Washer - Top Loading
Maytag LAT9356ABE Washer - Top Loading
Maytag LAT9356ABM Washer - Top Loading
Maytag LAT9357AAE Washer - Top Loading
Maytag LAT9357AAM Washer - Top Loading
Maytag LAT9357AAQ Washer - Top Loading
Maytag LAT9360AAE Washer - Top Loading
Maytag LAT9390AAE Washer - Top Loading
Maytag LAT9400AAE Washer - Top Loading
Maytag LAT9400AAL Washer - Top Loading
Maytag LAT9400AAW Washer - Top Loading
Maytag LAT9400ABE Washer - Top Loading
Maytag LAT9400ABL Washer - Top Loading
Maytag LAT9400ABW Washer - Top Loading
Maytag LAT9400AGL Washer - Top Loading
Maytag LAT9400AGW Washer - Top Loading
Maytag LAT9400AGX Washer - Top Loading
Maytag LAT9400DAL Washer - Top Loading
Maytag LAT9400DAW Washer - Top Loading
Maytag LAT9406AAE Washer - Top Loading
Maytag LAT9406AAM Washer - Top Loading
Maytag LAT9406ABE Washer - Top Loading
Maytag LAT9416AAE Washer - Top Loading
Maytag LAT9416AAM Washer - Top Loading
Maytag LAT9416AAQ Washer - Top Loading
Maytag LAT9420AAE Washer - Top Loading
Maytag LAT9457AAE Washer - Top Loading
Maytag LAT9457AAM Washer - Top Loading
Maytag LAT9457AAQ Washer - Top Loading
Maytag LAT9457BAE Washer - Top Loading
Maytag LAT9520AAE Washer - Top Loading
Maytag LAT9520AAQ Washer - Top Loading
Maytag LAT9557AAE Washer - Top Loading
Maytag LAT9557AAM Washer - Top Loading
  #2 (permalink)
Old 06-22-2009, 04:24 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
The likely culprits are either the water temp selection switch or the timer. Logic would say its the timer, but the water temp switch is the less expensive part to experiment with as a cure.
Replacement parts for MAYTAG LAT8840BAW | AppliancePartsPros.com
Neither is excessively expensive, so try one, if that does not fix it try the other.
Sorry I could not be more definitive. Good luck, and post your results so we and the viewers will know what to expect next time.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Gold Accubake temperature setting sforman1 Oven Repair (including Ranges and Cooktops) 6 05-16-2009 07:47 PM
Freezer temperature problem, fan? doasc Refrigerator & Freezer Repair 3 04-08-2009 12:15 PM
temperature problem wparker824 Oven Repair (including Ranges and Cooktops) 0 12-30-2008 10:14 AM
Washer problem in LARGE load setting- timer problem? jagtianis Washer Repair 9 08-04-2008 02:49 AM
GE Double Oven shows it is at temperature setting but is 100 degress less. mitcrellim Oven Repair (including Ranges and Cooktops) 0 04-05-2008 10:00 PM
