hernandozoo
#1 Posted : Friday, December 9, 2011 4:20:46 PM(UTC)
hernandozoo
Have changed the flow meter and acturator,but still no water flow during wash cycle. Can put over to rinse cycle and drum fills up.After water runs threw dispenser and then should continue to fill, there is a buzzing noise.Any ideas?
ApplianceJunk
#2 Posted : Friday, December 9, 2011 4:58:18 PM(UTC)
ApplianceJunk
Can you tell were the buzzing noise is coming from?
If it's coming from the water inlet valve then chances are that's the problem.
hernandozoo
#3 Posted : Sunday, December 11, 2011 9:22:47 AM(UTC)
hernandozoo
Buzzing noise seems to be coming from gray box where all wires plug into. I'm guessing that's the "brain". Buzzing isn't very loud ,but is noticeable if top off machine.I thought it was a stuck relay switch,no such luck.
ApplianceJunk
#4 Posted : Sunday, December 11, 2011 9:31:24 AM(UTC)
ApplianceJunk
Here is the tech sheet for your model. It will tell you how to run it through diagnostics. See if you can get it to fill during the diagnostic test.
Could be a bad control board.
File Attachment(s):
Tech Sheet - 8181790.pdf (147kb) downloaded 7 time(s).
hernandozoo
#5 Posted : Monday, December 12, 2011 3:27:56 PM(UTC)
hernandozoo
is there a test to check board? thanks for the tech.sheet
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew 12/6/2023 1:02:46 PM(UTC)
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
no water dispensing out of door (Refrigerator & Freezer Repair)
by montyrt@gmail.com 4/2/2023 9:08:51 AM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and eject (Refrigerator & Freezer Repair)
by Guest 5/15/2022 6:57:18 AM(UTC)
LG lfx31945 no water (Refrigerator & Freezer Repair)
by azurebat 11/29/2021 2:45:31 PM(UTC)
Water dispenser has no water but gushes inside fridge compartment when activated (Refrigerator & Freezer Repair)
by xclr8 11/20/2021 12:39:21 PM(UTC)
Ice maker arm works, but no water (Refrigerator & Freezer Repair)
by dean8433 11/16/2021 10:05:30 AM(UTC)
Maytag Washer - no water (Washer Repair)
by maalfunction 11/2/2021 6:52:56 AM(UTC)
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 8/26/2021 6:48:33 PM(UTC)
Ice Maker Receiving No Water (Refrigerator & Freezer Repair)
by tibrbk 5/31/2021 10:19:02 AM(UTC)
no water getting to ice maker but water dispenser works (Refrigerator & Freezer Repair)
by bdevlin 1/11/2021 2:18:45 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 9/5/2020 4:57:43 PM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
