| » whirlpool extra care system stops at rinse cycle |
Model Number: wtw53215qo Brand: Whirlpool Age: 1 - 5 years
I had found similar topics on this subject but not for the same model number washer. The unit stops during the wash as soon as it hits the rinse cycle and the water drains. It hums a little but nothing else. I am wondering what the issue may be.
I apologize if this question has already been answered, truly. Matt Ads By Google Related Models |
The washer uses cold water for the rinse cycle. Could be that it's not getting any cold water because the screen in the water inlet valve is plugged or the water valve is bad and needs to be replaced.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
To check the screens in the water inlet valve you need to turn the hot and cold water inlet hoses off and remove them from the back of the washer. You will then be able to look into the water inlet valve and see the screens to see if they are plugged up.
To check the water inlet valve to see if it's bad you would check the coils for continuity with a ohm meter. This video will show you how to replace the water inlet valve. Washer Water Inlet Valve (part #285805) - How To Replace - YouTube
__________________
Your welcome, let me know how it works out for you or if you have any other questions.
__________________
| Display Modes | |
| Whirlpool Ultimate Care II Washer won't Rinse after Wash Cycle | missfixit | Washer Repair | 20 | 08-10-2012 09:12 PM |
| Whirlpool Washer stops at the rinse cycle | Janemarie | Washer Repair | 1 | 10-16-2011 06:41 PM |
| Betsy-Whirlpool washer-stops at rinse cycle | jrkf | Washer Repair | 1 | 06-15-2011 06:30 AM |
| Dishwasher skips the wash cycle and stops at the rinse cycle | jasporo | Dishwasher Repair | 6 | 06-08-2009 04:11 PM |
| Stops 3/4 through fill on rinse cycle | jamman | Washer Repair | 3 | 03-15-2009 10:18 AM |
