Here are your parts. Replacement parts for WHIRLPOOL LTE6234DQ1 | AppliancePartsPros.comYou will also have to purchase the spanner tool to remove the spanner nut. This is not a difficult repair, but it will take time and you will need to remove the cabinet, agitator and basket and tub. It will take time. First I would take the cabinet off and see if you have oil splattered on the inside. If so, water got into your transmission and it will likely have to be replaced also. If you decide to go ahead I recommend you purchase the Whirlpool Direct Drive service manual from this site. (Don't use the screw driver method in there to remove the spanner nut, buy the special tool) Good luck, let us know what you decide
