| » Fh Code No Or Insufficient Water Supply |
Model Number: GHWg150PW0 Brand: Whirlpool Age: 1 - 5 years
I Checked And The Faucets Are On, Checked The Inlet Screens, Hoses Are Not Kinked, And Water Hoses Are Not Frozen. What Could Be The Problem?
Related Models |
Replacement parts for WHIRLPOOL GHW9150PW0 | AppliancePartsPros.com Here is a tech sheet https://www.servicematters.com/docs/...%208182277.pdf Here is a service manual for a 9100, I believe the 9150 is fairly close to this unit so hopefully it will help https://secured.whirlpool.com/Servic...0Job%20Aid.pdf I am assuming that when you checked you water supply you ran the hoses into a pail to be sure they were OK. The reason is that hoses can collapse internally usually though you see a bulge on them, also many new homes have a hose burst system which can cause problems. Try hot only and cold only to see if one of theses will work. The tech sheet should help you narrow it down.
__________________
Quote:
Thank you so much, I will check the hoses better, and check out the teck sheet. THANK YOU AGAIN. |
Quote:
It's not that my washer isn't geting enough water, its getting to much water then it beeps and flashes FH then it stops and drains all the water out. Is there a part that lets the washer know when to shut the water off. I even push pause button and then push the start button again and it dose the same thing over again. |
| Display Modes | |
| Water supply leaking - HELP! | davinci144 | Refrigerator & Freezer Repair | 1 | 05-25-2009 06:49 AM |
| Kenmore - Water supply problem | wdj03 | Refrigerator & Freezer Repair | 3 | 09-23-2008 11:40 AM |
| Insufficient Cooling | KenPaul | Refrigerator & Freezer Repair | 9 | 08-19-2008 06:53 AM |
| no water supply | tkhighlander | Refrigerator & Freezer Repair | 1 | 08-10-2008 11:18 PM |
| Icemaker water supply | GeorgeSlater | Refrigerator & Freezer Repair | 0 | 12-19-2007 08:26 AM |
