my agitator will not move when engaged it makes a hum sound timer still moves thru the cycles.... but the spin and rinse cycle works the coupling is fine the seal was a lil worn the shavings were very noticable and the dogs were in good condition please help:confused:
Can you tell if the humming sounds is coming from the main motor at the bottom of the washer?
Originally Posted by: ApplianceJunk Hi,
Can you tell if the humming sounds is coming from the main motor at the bottom of the washer? no can not tell :(
If the motor is drawing high current, the internal overload will kick off and stay off for a relatively long period. If so, you probably have bad timer contacts, remove cover and check.
