| » Suspension Rod and spring assembly |
Model Number: WPSE4200A0WW Brand: GE Age: 5 - 10 years
I have a GE prodigy washer, Model # WPSE4200A0WW. The tub was sitting very low in the washer and when the tub fill up with water it causes the pulley system and spring clip on the clutch assembly to grind against the bottom of the washer during agitation and spin cycle.
I've checked online posts and others recommended replacing the four suspension rods (2 yellow - front, 2 black - back. I ordered the replacement parts for my model AP2046168 (WH16X544) Suspension rod & spring assembly (black) 2 AP2046167 (WH16X543) Suspension rod & spring assembly (yellow) 2 and replaced each of the suspension rods. I loaded the washer on its lowest water setting and again even with only water, the spring clip on the clutch pressed against the bottom of the washer. Are the replacement parts defective or is there something else going on here. Would appreciate any help you could provide. Ads By Google Related Models |
I think there is something else going on here, but this is one of those things you need to be looking at to see the problem.
I am wondering if something is broken in the pulley/drive system, take a look.
__________________
Thanks for the quick reply.
The pulley and drive system looks okay. Belt is fine. As the washer drains and the tub spins during the spin cycle there are no strange sounds or burning smells. The apron doesn't look bent around the top. The suspension rods just don't seem to be holding the weight the way they were designed to. Any ideas? Thanks. Tom |
| Display Modes | |
| suspension spring? | ceeyahd1 | Washer Repair | 2 | 01-12-2011 08:22 AM |
| Detergent door spring assembly | jeffjack | Dishwasher Repair | 0 | 10-17-2010 11:17 AM |
| Replacing Rod & Spring suspension on WCRE6270D1WW | bdlindberg | Washer Repair | 2 | 09-17-2010 11:49 AM |
| Whirlpool Thin Twin Suspension Assembly | Lisamarie28 | Washer Repair | 1 | 03-21-2010 06:34 AM |
| Suspension Spring Hooks | Michigan01 | Washer Repair | 1 | 03-14-2009 11:29 AM |
