Discuss
GE washer motor will not run
 in
Washer Repair
Washer motor will not run on any cycle, schematic is incomplete, shows no motor or timer, wires go to motor
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer motor will not run
  #1 (permalink)
Old 12-27-2007, 09:47 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default GE washer motor will not run
Model Number: wjrr4170goww   Brand: GE   Age: Less than 1 year
Washer motor will not run on any cycle, schematic is incomplete, shows no motor or timer, wires go to motor and timer but just stop!!
Suspect internal motor thermal fuse. One data base shows parts, but no motor!
__________________
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-27-2007, 11:46 AM
TechnicianBrian's Avatar
TechnicianBrian TechnicianBrian is offline
Senior Expert
APP Volunteer
TechnicianBrian is on a distinguished road
Default
There is no thermal fuse on that motor, and if you show voltage to the motor, you will need to replace the whole thing WH20X10035. One thing to try is follow the wire harness up the right side until it gets bundled together with heat shrink. Inside you will find an in-line thermal fuse on the neutral line to the motor. See if it's open. I am about 50/50 on replacing motors or fuses.
__________________
TechnicianBrian
TechnicianBrian.com
  #3 (permalink)
Old 12-27-2007, 12:21 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Richappy
This is a new GE Profile washer with a new variable speed inverter/motor assembly. The motor status is displayed through a series of flash codes from a green LED located on the front side of the inverter just above the motor. It has the inline fuse (in the lid switch harness) which disables the motor.
It also has a shaft and mode shifter assembly instead of a transmission.
It suppose to be a mini-manual inside the control panel.
Happy New year!
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 12-27-2007, 03:36 PM
Senior Expert
APP Volunteer
Default
Thanks Gene and TechnicianBrian:
Fuse was good, motor open. Never saw a schematic so screwed up, like they fired the draftsman before he could complete it!!
Happy New year to you both, will be watching the Penn. State, Texas A&M bowl game Saturday
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool washer motor needs help to start jes999 Washer Repair 3 12-16-2007 10:36 AM
Washer motor will not run den1 Washer Repair 0 12-13-2007 10:08 AM
Questions about motor in my Maytag washer yzhong Washer Repair 1 11-05-2007 08:24 PM
GE Washer - Motor Intermittent rmfield Washer Repair 3 11-01-2007 09:01 PM
Washer motor spins but will not agitate. jimmyr Washer Repair 1 09-19-2007 05:34 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
