Discuss
gusmcc
 in
Washer Repair
Our Kirkland clothes washer (made by Whirlpool), model #SAWS800HQ0, is leaking water out the bottom. The water is not coming
Appliance Repair Forum > Appliance Repair Help > Washer Repair » gusmcc
  #1 (permalink)
Old 06-19-2009, 02:05 PM
gusmcc gusmcc is offline
Junior Member
gusmcc is on a distinguished road
Default gusmcc
Model Number: SAWS800HQ0   Brand: Whirlpool   Age: 5 - 10 years
Our Kirkland clothes washer (made by Whirlpool), model #SAWS800HQ0, is leaking water out the bottom. The water is not coming from a water hose or the drain hose. I suspect it is coming from the pump. How do I diagnose the problem and what parts will I need.
Related Models
Whirlpool SAWS800HQ0
Whirlpool SAWS800JQ0
Whirlpool SAWS800JQ1
Whirlpool SAWS800JQ2
Whirlpool SAWS800MQ0 Automatic Washer
Whirlpool SAWS900HQ0
Whirlpool SAWS900JQ0
Whirlpool SAWS900MQ0 Automatic Washer
Whirlpool SAWX650JQ0
Whirlpool SAWX650MQ0 Automatic Washer
Whirlpool SAWX650MQ2 Automatic Washer
Whirlpool SB1000SKN0
Whirlpool SB100PEDB0
Whirlpool SB100PEDB1
Whirlpool SB100PEDB2
Whirlpool SB100PEDB4
Whirlpool SB100PEDB5
Whirlpool SB100PEK0
Whirlpool SB100PEK1
Whirlpool SB100PER0
Whirlpool SB100PES0
Whirlpool SB100PES1
Whirlpool SB100PES2
Whirlpool SB100PES3
Whirlpool SB100PES4
Whirlpool SB100PSK0
Whirlpool SB100PSK1
Whirlpool SB100PSR0
Whirlpool SB100PSR1
Whirlpool SB130PEDB0
Whirlpool SB130PEDB1
Whirlpool SB130PEDB2
Whirlpool SB130PEK0
Whirlpool SB130PER1
Whirlpool SB130PER2
Whirlpool SB130PER3
Whirlpool SB130PER4
Whirlpool SB130PER5
Whirlpool SB130PERW0
Whirlpool SB130PSK0
Whirlpool SB160PEDB0
Whirlpool SB160PEDB1
Whirlpool SB160PEDB2
Whirlpool SB160PEDB4
Whirlpool SB160PEDQ0
Whirlpool SB160PEDQ1
Whirlpool SB160PEDQ2
Whirlpool SB160PEDQ4
Whirlpool SB160PEEB1
Whirlpool SB160PEEB2
Whirlpool SB160PEEB5 24" Built - in - Oven Gas
Whirlpool SB160PEEB6
Whirlpool SB160PEEB7
Whirlpool SB160PEEB8
Whirlpool SB160PEEB9
Whirlpool SB160PEEQ1
Whirlpool SB160PEEQ2
Whirlpool SB160PEEQ5 24" Built - in - Oven Gas
Whirlpool SB160PEEQ6
Whirlpool SB160PEEQ7
Whirlpool SB160PEEQ8
Whirlpool SB160PEEQ9
Whirlpool SB160PEXB0
Whirlpool SB160PEXB1
Whirlpool SB160PEXQ0
Whirlpool SB160PEXQ1
Amana SB21VE Ref - SXS/I&W
Amana SB21VPSE Ref - SXS/I&W
Amana SB21VW Ref - SXS/I&W
Thermador SB2B
Amana SB520K Ref - SXS/I&W
Amana SB520SW Ref - SXS/I&W
Amana SB520TW Ref - SXS/I&W
Amana SBC24FX0 Range - Electric Std Delaware
Amana SBC24FX5 Range - Electric Std Delaware
Amana SBC24FXOW Range - Electric Std Delaware
Amana SBC26CK Range - Electric Std Delaware
Amana SBD20H Ref - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K Ref - SXS/I&W
Amana SBD20M Ref - SXS/I&W
Amana SBD20MW Ref - SXS/I&W
Amana SBD20NE Ref - SXS/I&W
Amana SBD20NW Ref - SXS/I&W
Amana SBD20Q2E Ref - SXS/I&W
Amana SBD20Q2W Ref - SXS/I&W
Amana SBD20S4E Ref - SXS/I&W
Amana SBD20S4L Ref - SXS/I&W
Amana SBD20S4W Ref - SXS/I&W
Amana SBD20TPE Ref - SXS/I&W
Amana SBD20TPL Ref - SXS/I&W
Amana SBD20TPSW Ref - SXS/I&W
Amana SBD20TPW Ref - SXS/I&W
Amana SBD21VE Ref - SXS/I&W
Amana SBD21VL Ref - SXS/I&W
Amana SBD21VPE Ref - SXS/I&W
Amana SBD21VPSE Ref - SXS/I&W
Amana SBD21VW Ref - SXS/I&W
Amana SBD522VE Ref - SXS/I&W
Amana SBDE20S4SW Ref - SXS/I&W
Amana SBDE20TPE Ref - SXS/I&W
Amana SBDE20TPW Ref - SXS/I&W
  #2 (permalink)
Old 06-21-2009, 07:36 AM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
You will want to take the cabinet off, and if you cannot see where the leak is coming from, run it with the cabinet off to locate the leak.
Take the two screws that hold the console to the cabinet out and flip up the console. Unhook the lid switch and use a flat blade screw driver to take off the two clips that hold the cabinet to the back. The cabinet will not tilt towards you and come off. If you have to operate it by-pass the lid switch by inserted an insulated solid wire into the two outer holes of the plastic clip coming from the console.
If it's the pump, remove the two clips that hold it on, and disconnect it from the hoses (get ready for a lot of water to come out). Pull the pump off, replace it and put the machine back together and you are set to go.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
