F2 error code, constant beeping
Washer Repair
My mom's Kenmore Elite washer beeps constantly and gives an F2 code. I can silence it with the stop button.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » F2 error code, constant beeping
  #1 (permalink)
Old 12-07-2011, 12:38 PM
Junior Member
Henry J is on a distinguished road
Default F2 error code, constant beeping
Model Number: 110.28032700   Brand: Kenmore   Age: Less than 1 year
My mom's Kenmore Elite washer beeps constantly and gives an F2 code. I can silence it with the stop button. It will start again if the machine is even slightly jarred.From other posts on Kenmore Elite models with same problem - it sounded like a clogged pump filter. I tried to pull the machine apart to remove the filter from the bottom of the tub. I took off the back cover and pulled all of the hoses from the two pumps at the bottom of the tub. I checked the hoses and pumps and all seem clear. I do not know how to get to the filter though. It seems like I will have to pull the drum to get to it. I tried to remove the top cover of the machine. I removed the two clips on the back side of the top cover but it seems like I will have to remove the drum suspension rods from the underside of the cover to pull up the front of it. I gave up on it and put everything back together. Any help is appreciated. Thanks!
Related Models
Hoover 1100
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11012202100 WASHER
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Mini oven board beeping with no error code Marty7w Oven Repair (including Ranges and Cooktops) 0 06-06-2011 04:35 PM
constant beeping FARYMON Refrigerator & Freezer Repair 0 09-08-2010 10:59 AM
F-7 error code magic chef started beeping this A boblf Oven Repair (including Ranges and Cooktops) 6 05-28-2009 01:41 AM
GE Profile Dishwasher - constant beeping Chris24 Dishwasher Repair 0 02-25-2009 06:31 PM
F1 Error Code - Continuous Beeping!! Derrick Cote Oven Repair (including Ranges and Cooktops) 9 10-06-2008 04:27 PM
