Discuss
maytag washer no hot water
 in
Washer Repair
Hot water won't run. When hot is selected on Control Panel, the machine doesn't come on. When warm or cold
Appliance Repair Forum > Appliance Repair Help > Washer Repair » maytag washer no hot water
  #1 (permalink)
Old 12-07-2011, 12:18 PM
Junior Member
lindaa is on a distinguished road
Default maytag washer no hot water
Model Number: la712   Brand: Maytag   Age: More than 10 years
Hot water won't run. When hot is selected on Control Panel, the machine doesn't come on. When warm or cold is selected, the water flows into the tub but it is cold water.
Related Models
Maytag LA712 WASHER-TOP LOADING
Maytag LA7300 WASHER-TOP LOADING
Maytag LA7400 WASHER-TOP LOADING
Whirlpool LA7400XMW0
Whirlpool LA7400XMW1
Whirlpool LA7400XMW2
Whirlpool LA7400XMW3
Whirlpool LA7450XMW0
Whirlpool LA7450XMW1
Whirlpool LA7460XMW0
Maytag LA7500 WASHER-TOP LOADING
Maytag LA7500S WASHER-TOP LOADING
Maytag LA7500W WASHER-TOP LOADING
Whirlpool LA7500XKW0
Frigidaire LA750EXD3 Wwh(v6) / Washer
Frigidaire LA750EXF3 Wwh(v7) / Washer
Frigidaire LA750EXH3 Wwh(v8) / Washer
Frigidaire LA750EXV3 Wwh(v9) / Washer
Frigidaire LA750EXW3 Wwh(v10) / Washer
Frigidaire LA750MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA750MXW1 Wwh(v1) / 27 " Washer
Whirlpool LA7680XKW1
Whirlpool LA7680XKW2
Whirlpool LA7680XMW0 Washers*
Whirlpool LA7680XPW0
Whirlpool LA7680XPW1
Whirlpool LA7680XPW2
Whirlpool LA7680XSW0
Whirlpool LA7680XSW1
Whirlpool LA7680XTF0
Whirlpool LA7680XTF1
Whirlpool LA7680XTG0
Whirlpool LA7680XTG1
Whirlpool LA7680XTM0
Whirlpool LA7680XTM1
Whirlpool LA7680XTN0
Whirlpool LA7680XTN1
Whirlpool LA7680XTW0
Whirlpool LA7680XTW1
Whirlpool LA7681XSW0
Whirlpool LA7681XSW1
Whirlpool LA7685XKW1
Whirlpool LA7685XPW0
Whirlpool LA7685XPW1
Whirlpool LA7685XPW2
Whirlpool LA7700XPW0
Whirlpool LA7700XPW1
Whirlpool LA7700XPW3
Whirlpool LA7700XPW4
Whirlpool LA7700XPW5
Whirlpool LA7700XSW0
Whirlpool LA7700XWN0
Whirlpool LA7700XWW0
Whirlpool LA7780XSW0
Whirlpool LA7780XSW1 Washers*
Whirlpool LA7780XSW2
Maytag LA7800 WASHER-TOP LOADING
Whirlpool LA7800XKW2
Whirlpool LA7800XMW0
Whirlpool LA7800XPW0
Whirlpool LA7800XPW1 Washers*
Whirlpool LA7800XSF2 AUTOMATIC WASHER
Whirlpool LA7800XSG2 AUTOMATIC WASHER
Whirlpool LA7800XSM2 AUTOMATIC WASHER
Whirlpool LA7800XSN1 AUTOMATIC WASHER
Whirlpool LA7800XSN2 AUTOMATIC WASHER
Whirlpool LA7800XSW0
Whirlpool LA7800XSW1
Whirlpool LA7800XSW2
Whirlpool LA7800XTF0 AUTOMATIC WASHER
Whirlpool LA7800XTF1 AUTOMATIC WASHER
Whirlpool LA7800XTG0 AUTOMATIC WASHER
Whirlpool LA7800XTG1 AUTOMATIC WASHER
Whirlpool LA7800XTM0 AUTOMATIC WASHER
Whirlpool LA7800XTM1 AUTOMATIC WASHER
Whirlpool LA7800XTN0 AUTOMATIC WASHER
Whirlpool LA7800XTN1 AUTOMATIC WASHER
Whirlpool LA7800XTW0
Whirlpool LA7800XTW1
Whirlpool LA7801XTF0
Whirlpool LA7801XTG0
Whirlpool LA7801XTM0
Whirlpool LA7801XTN0
Whirlpool LA7801XTW0
Whirlpool LA7899XPW3
Whirlpool LA7900XPW1
Whirlpool LA7900XSW0
Whirlpool LA7900XSW1
Whirlpool LA7900XSW2
Whirlpool LA7900XTF0
Whirlpool LA7900XTG0
Whirlpool LA7900XTG1
Whirlpool LA7900XTM0
Whirlpool LA7900XTN0
Whirlpool LA7900XTN1
Whirlpool LA7900XTW0
Whirlpool LA7900XTW1
Whirlpool LA7980XSW0
Frigidaire LA800AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA800AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA800AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA800AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA800JXD4 Wwh(v1) / Washer
Frigidaire LA800JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA800JXF4 Wwh(v2) / Washer
Frigidaire LA800JXH4 Wwh(v3) / Washer
Frigidaire LA800JXH5 Wwh(v2) / Top Load Washer
Frigidaire LA800JXV4 Wwh(v4) / Washer
Frigidaire LA800JXW4 Wwh(v5) / Washer
Frigidaire LA800JXW5 Wwh(v3) / Top Load Washer
Frigidaire LA800MXD1 Wwh(v9) / 27 " Washer
Frigidaire LA800MXD2 Wwh(v9) / 27 " Washer
Frigidaire LA800MXH1 Wwh(v8) / 27 " Washer
Frigidaire LA800MXH2 Wwh(v8) / 27 " Washer
Frigidaire LA800MXW1 Wwh(v7) / 27 " Washer
Frigidaire LA800MXW2 Wwh(v7) / 27 " Washer
Maytag LA806 WASHER-TOP LOADING
Maytag LA806S WASHER-TOP LOADING
Maytag LA810 WASHER-TOP LOADING
Maytag LA8100 WASHER-TOP LOADING
  #2 (permalink)
Old 12-08-2011, 07:07 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
It could be the timer or the temp selection switch, but I think it is the valve assembly.
See if you can use a meter to see if 120v is getting to the hot water valve when the machine calls for hot water. If so, replace the valve assembly.
Before doing anything check that the hot water faucet is ok and that there is nothing blocking the hot water in the valve assembly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag washer/dyer combo washer no water lindavanzandt Washer Repair 1 01-18-2015 06:44 PM
Maytag Washer Leaking Water into Tub mightypasta Washer Repair 3 11-21-2011 10:29 AM
Maytag Washer - Will fill with water but that's it chibluz Washer Repair 5 03-02-2011 05:19 PM
Maytag Washer doesn't spin all water out ltnacc Washer Repair 1 10-04-2009 07:40 AM
Maytag Washer No Water TimW Washer Repair 0 10-29-2007 06:24 AM
