Fuse that feeds power to the motor blew. I cut the fuse out placed a jumper untill new fuse comes in. Washer working ok. Was told that once the fuse blows also means motor defective? can i keep running the washer with out the fuse untill fuse comes in ? washer works ok?
A blown fuse does not mean the motor is bad, fuses blow all the time. So you should have a very inexpensive repair. However, you do need to stop using the machine until you have a fuse in there. While the motor is probably ok, you run the risk of blowing it out without the fuse, so don't turn an inexpensive problem into an expensive replacement of the entire machine.
