| » Washer will not agitate but will pump and spin |
Model Number: 417.99872990 Brand: Kenmore Age: 5 - 10 years
Kenmore stack wash/dry 417.99872990. After done filling tub with water the washer motor hums loudly, blows circuit breaker after few minutes. Pump and spin cycle work well, but will not agitate. Has anyone seen something like this? What should I look at next?
Thanks! Ads By Google Related Models |
Remove the front kick panel of the washer, remove the belt, and turn the tranny pulley in the agitate direction. If jammed, you have a bad tranny. Post results.
__________________
Turn the tranny pulley in the agitate direction. When it engages, can you feal "rough" spots in the tranny? If not, your tranny is probably ok. A verification of this would be the lack of a burnt belt.
Turn the timer to wash cycle, remove timer and cover. Check the contacts that should be closed. If you find any burnt ones, you have a bad timer. If ok, check the tranny pulley when you put it in wash, if it turns, then abruptly stops. you have a bad tranny.
__________________
Usually on a burnt/shorted start winding you can see it, just look inside the motor.Or with a good digital meter, you could confirm a short per the schematic
Best price I found is right here, Part # AP3219509 $91
__________________
| Display Modes | |
| Replaced pump. Spin yes, agitate no. | bakjar | Washer Repair | 2 | 03-09-2009 05:06 PM |
| GE topload will not agitate/spin will pump | Alizabeth | Washer Repair | 1 | 02-23-2009 06:09 PM |
| kenmore 70 series washer will not agitate/spin + rusty drive shaft/pump | pkme | Washer Repair | 2 | 01-27-2009 07:55 AM |
| Roper washer will not spin, agitate, pump | litexp2 | Washer Repair | 16 | 09-26-2008 12:53 PM |
| maytag will not spin agitate or pump | drembo | Washer Repair | 7 | 12-25-2007 02:37 AM |
