Fabric softener does not work.I replaced dispensor acturator assembly .Still does not work,what could be wrong?
If you did not clean out the tube going to the waster then do so, and if you did check it out again.
If that all checks out, lookunder the top for tgech notes that will show you how to put it into test mode and see if there is a way to test the control unit.
