I have a lg wn1812cw washer. It has an error code oe. I cleaned out the screen, washed out the tube to pump, washed out drain hose to wash tube. I then ran a rince and spin with no cloths. It worked fine. I did a small load and got the oe code. It won't drain.
I could not find any information on a model wn1812cw are you sure that is the correct model number? What brand is this washer, LG?
Originally Posted by: ApplianceJunk Hi,
I could not find any information on a model wn1812cw are you sure that is the correct model number? What brand is this washer, LG? opps typo, wm1812cw LG make
