Discuss
Washer not spinning
 in
Washer Repair
My Whirlpool LSR7333PQ0 will seldom spin on it's own. I can turn the tub CW and CCW to get it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer not spinning
  #1 (permalink)
Old 12-05-2011, 05:20 PM
Junior Member
mikex30 is on a distinguished road
Default Washer not spinning
Model Number: LSR7333PQ0   Brand: Whirlpool   Age: 5 - 10 years
My Whirlpool LSR7333PQ0 will seldom spin on it's own. I can turn the tub CW and CCW to get it to spin. Some times it takes a couple attempts to make it spin. I disassembled the washer and looked at the motor/tranny/clutch assy. I could barely see in to the brake/clutch area. I was tempted to use a spray lube like WD-40, I didn't spray anything. I did clean between the drum and tub with hot water. I am thinking the clutch/brakes may be the issue. Need some pointers.
I did find the replacement clutch assy for about $125 plus tax + shipping. I don't have any special tools to remove the agitator if needed, do I nee to remove the agitator?
Mike
Related Models
Whirlpool LSR7333PQ0 AUTOMATIC WASHER
Whirlpool LSR7333PQ1 AUTOMATIC WASHER
Whirlpool LSR7333PQ3 AUTOMATIC WASHER
Whirlpool LSR7333PQ4 AUTOMATIC WASHER
Whirlpool LSR8010PQ0 AUTOMATIC WASHER
Whirlpool LSR8010PQ1 AUTOMATIC WASHER
Whirlpool LSR8010PQ2 AUTOMATIC WASHER
Whirlpool LSR8010PT0 AUTOMATIC WASHER
Whirlpool LSR8010PT1 AUTOMATIC WASHER
Whirlpool LSR8010PT2 AUTOMATIC WASHER
Whirlpool LSR8133HQ0 AUTOMATIC WASHER
Whirlpool LSR8133HZ0 AUTOMATIC WASHER
Whirlpool LSR8200EQ0 AUTOMATIC WASHER
Whirlpool LSR8200EZ0 AUTOMATIC WASHER
Whirlpool LSR8233EQ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EQ1 AUTOMATIC WASHER
Whirlpool LSR8233EZ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EZ1 AUTOMATIC WASHER
Whirlpool LSR8233JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JQ1 WASHER
Whirlpool LSR8233JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JT1 WASHER
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0 WASHER
Whirlpool LSR8433KQ1 AUTOMATIC WASHER
Whirlpool LSR8433KQ2 AUTOMATIC WASHER
Whirlpool LSR8433KT0 WASHER
Whirlpool LSR8433KT1 AUTOMATIC WASHER
Whirlpool LSR8433KT2 AUTOMATIC WASHER
Whirlpool LSR8444LQ0 WASHER
Whirlpool LSR8444LQ1 AUTOMATIC WASHER
Whirlpool LSR8444LT0 WASHER
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 AUTOMATIC WASHER
Whirlpool LSR9434PQ1 AUTOMATIC WASHER
Whirlpool LSR9434PQ3 AUTOMATIC WASHER
Whirlpool LSR9434PQ4 AUTOMATIC WASHER
Whirlpool LSR9434PT0 AUTOMATIC WASHER
Whirlpool LSR9434PT1 AUTOMATIC WASHER
Whirlpool LSR9434PT3 AUTOMATIC WASHER
Whirlpool LSR9434PT4 AUTOMATIC WASHER
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
General Electric LSS25XSWASS REFRIGERATOR W SERIES
General Electric LSS25XSWCSS REFRIGERATOR W SERIES
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0 WASHER
Whirlpool LSS9244EZ0 WASHER
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
  #2 (permalink)
Old 12-05-2011, 05:26 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Not sure what you were looking at for $125, but here is the clutch for your washer.
WHIRLPOOL Clutch Assembly, part number: AP3094537
I would try and run it with the cabinet removed so you can watch the clutch.
You will have to jump out the lid switch to do it.
The clutch could be slipping, you could have something caught between the basket and outer tub or the drive block under the agitator could be stripped out.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 12-05-2011, 05:44 PM
Junior Member
Default
I had the cabinet off. There is only about a quarter inch of clearance to to see the break area. While I had the cabinet off the dang thing spun fine, I figured it thought I was the repairman and would run fine. Like when you bring your car in to the mechanic.
The parts assy I was looking at had a shaft, clutch and breaks. To check between the tub and basket I would need to remove the agitator, no tool to remove it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer is not spinning basu Washer Repair 0 08-14-2011 03:01 PM
washer not spinning golfman Washer Repair 24 02-08-2011 05:37 PM
washer not spinning shipee1 Washer Repair 0 04-08-2010 03:03 PM
Washer not spinning laura12345 Dishwasher Repair 2 02-27-2010 09:07 PM
Washer no spinning royrodgers Washer Repair 1 12-28-2009 02:42 AM
