Discuss
Maytag Spin Problem
 in
Washer Repair
I have a Maytag top loading wash machine. When it goes into the spin cycle it makes a fast loud
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Spin Problem
  #1 (permalink)
Old 12-26-2007, 10:15 AM
big red 2000 big red 2000 is offline
Junior Member
big red 2000 is on a distinguished road
Default Maytag Spin Problem
Model Number: SAV2555AWW   Brand: Maytag   Age: 1 - 5 years
I have a Maytag top loading wash machine. When it goes into the spin cycle it makes a fast loud popping noise (water is draining but tub is not spinnning). I looked at it and the plastic helix on the very bottom of the drive was not staying engaged in the spin cycle. It engages fine in wash mode. I replace the spin pulley and plastic helix thinking it was just worn out. Worked great for about three weeks and now it is doing the exact same thing again. Any advice?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-26-2007, 02:25 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem with your washer is a bad triple lip seal.
You can find the complete instructions how to replace the triple lip seal and bearing in the Maytag bulletin.
You will need a few special tools. The part numbers you can find in the bulletin.
- The part number for the triple lip seal and bearing assembly is
AP4260929
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-26-2007, 05:42 PM
Junior Member
Default
After I read your response I looked at my machine again. I noticed that the shaft moves up and down about a half an inch. I am assuming that it shouldn't and that's why the small plastic helix is not engaging during the spin cycle. Am I correct.
  #4 (permalink)
Old 12-26-2007, 05:51 PM
Junior Member
Default
  #5 (permalink)
Old 12-26-2007, 07:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like a bad transmission.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune wont spin Stokes Washer Repair 0 12-15-2007 12:59 PM
drain/spin problem lymtics Washer Repair 1 10-29-2007 04:48 PM
Maytag Portable Dishwasher Problem carr65 Dishwasher Repair 0 09-06-2007 01:55 PM
Maytag DW door problem Grubby Dishwasher Repair 1 08-31-2007 04:38 PM
Maytag problem J-Reb Dryer Repair 1 07-27-2007 10:23 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
