| » not spinning all the water out of clothes |
Model Number: cav2000aww Brand: Magic Chef Age: 5 - 10 years
unit is not spinning all the water out of the clothes. i have to run it through the spin setting 2 -3 times. the belt looks ok. what else should i look for
Hi Griffith
If the belt is ok your problem can be in the transmission itself which might mean a new washer, or you could try replacing the pulley/bearing which comes as a kit and instructions and is not an expensive fix. This is a very likely source of your problem. Here is a good site on your type of washer http://www.applianceaid.com/norgewash.html Good luck, and let us know what you do and findout.
__________________
| Display Modes | |
| Clothes wet after spinning | jmafarm | Washer Repair | 1 | 07-26-2009 04:49 PM |
| Washer not spinning the water out | Gabesrepair | Washer Repair | 0 | 03-06-2009 05:13 PM |
| Water draining but tub not spinning | Coastal_Mapper | Washer Repair | 5 | 11-22-2008 07:45 AM |
| clothes washer wont spin, when I push down on the lid it starts spinning | property manager | Washer Repair | 1 | 11-11-2008 11:04 AM |
| pumps water in and out without spinning of the drum | punjabiflute | Washer Repair | 0 | 10-30-2007 04:36 PM |
