Our frigidaire front loading washer is not spinning. What could the problem be?
Take off the front panel under the door. You will find the service sheet there. You will need a meter to check things. Most likely problems, timer, door switch, or speed control board. If the speed control board, check your tub bearings for excesive drag.
