Discuss
calyspo washer issue
 in
Washer Repair
Have whirlpool washer with calypso wash motion, model GVW9959KQ2 purchased in 2003; unit is top loader with modified agitator to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » calyspo washer issue
  #1 (permalink)
Old 06-15-2009, 08:50 PM
rjeazmom rjeazmom is offline
Junior Member
rjeazmom is on a distinguished road
Default calyspo washer issue
Model Number: GVW9959KQ2   Brand: Whirlpool   Age: 5 - 10 years
Have whirlpool washer with calypso wash motion, model GVW9959KQ2 purchased in 2003; unit is top loader with modified agitator to use less water and pivot when washing. Unit worked fine until recently clothes began to slip below outer wash plate….U-joint was worn out, replace it with kit that included leveler, inner wash plate, etc…cleaned the unit thoroughly as crud had accumulated and had a moldy smell. Smell was virtually eliminated…use of liquid fabric softener is not recommended…after replacing parts clothes continue to slip past outer wash plate and basket. The flexible gasket that is on the perimeter of the outer wash plate was pointing up when the parts were changed out and it was believed it should be facing down so when reassembling unit after installation of u-joint reversed the direction of the flexible perimeter gasket to point down…a very snug fit between the outer wash plate and basket resulted but clothes still slip past the flexible gasket and get stuck, appreciate any insight as the flexible gasket was is now partially torn trying to release clothes that were partially slipped past it…which direction should the flexible gasket be pointing and does the replacement outer wash plate you offer include the rubber grommets recommended when it is changed out.
Related Models
Whirlpool GVW9959KQ2
Whirlpool GVW9959KQ3 Automatic Washer
Whirlpool GVW9959KT0
Whirlpool GVW9959KT1
Whirlpool GVW9959KT2
Whirlpool GVW9959KT3 Automatic Washer
Maytag GW18F1 Washer - Top Loading
Maytag GW18F1A Washer - Top Loading
Maytag GW18F1H Washer - Top Loading
Maytag GW18F1W Washer - Top Loading
Maytag GW18F2 Washer - Top Loading
Maytag GW18F2A Washer - Top Loading
Maytag GW18F2H Washer - Top Loading
Maytag GW18F2W Washer - Top Loading
Maytag GW18G1 Washer - Top Loading
Maytag GW18G100 Washer - Top Loading
Maytag GW18G124 Washer - Top Loading
Maytag GW18G125 Washer - Top Loading
Maytag GW18G1A Washer - Top Loading
Maytag GW18G1HW Washer - Top Loading
Maytag GW18G1WW Washer - Top Loading
Maytag GW20F6 Washer - Top Loading
Maytag GW20F600 Washer - Top Loading
Maytag GW20F624 Washer - Top Loading
Maytag GW20F625 Washer - Top Loading
Maytag GW20F6A Washer - Top Loading
Maytag GW20F6H Washer - Top Loading
Maytag GW20F6W Washer - Top Loading
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0
Whirlpool GW395LEGB1
Whirlpool GW395LEGB3
Whirlpool GW395LEGB4
Whirlpool GW395LEGB5
Whirlpool GW395LEGB6
Whirlpool GW395LEGQ0
Whirlpool GW395LEGQ1
Whirlpool GW395LEGQ3
Whirlpool GW395LEGQ4
Whirlpool GW395LEGQ5
Whirlpool GW395LEGQ6
Whirlpool GW395LEGT3
Whirlpool GW395LEGT4
Whirlpool GW395LEGT5
Whirlpool GW395LEGT6
Whirlpool GW395LEGZ0
Whirlpool GW395LEGZ1
Whirlpool GW395LEGZ3
Whirlpool GW395LEPB00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT00 30" Slide - in Gas Oven Non - Convect
Whirlpool GW395LEPT01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT05 30" Slide - in Gas Oven Non - Conv
Maytag GWC202 Dishwasher - Convertible
Maytag GWC204 Dishwasher - Convertible
General Electric GWR03AAMABB Refrigerator
Gibson GWS1149AS0 Washer - Gibson
Gibson GWS1149AS1 Washer - Gibson
Gibson GWS1339CS0 Gibson/washer
Gibson GWS1339CS1 Gibson/washer
Gibson GWS1749AS0 Washer - Gibson
Gibson GWS1749AS1 Washer - Gibson
Gibson GWS1749CS0 Gibson/washer
Frigidaire GWS223RFS0 Gib(v0) / Washer
Frigidaire GWS223RFS1 Gib(v0) / Washer
Frigidaire GWS223RHS0 Gib(v0) / Washer
Frigidaire GWS223RHS1
Frigidaire GWS445RFS0 Gib(v0) / Washer
Frigidaire GWS445RFS1 Gib(v1)
Frigidaire GWS445RFS2 Gib(v0) / Washer
Frigidaire GWS445RHS0 Gib(v0) / Washer
Gibson GWS445RHS1 Washer - Gibson
Frigidaire GWS645RBS0 Gib(v0) / 27 " Washer
Frigidaire GWS645RBS1 Gib(v0) / Washer
Frigidaire GWS645RBS2 Gib(v0) / Washer
Frigidaire GWS645RBS3 Gib(v0) / Washer
Frigidaire GWS645RBS4 Gib(v0) / Washer
Frigidaire GWS645RFS0 Gib(v0) / Washer
Frigidaire GWS645RFS1 Gib(v0) / Washer
Frigidaire GWS645RFS2 Gib(v0) / Washer
Frigidaire GWS645RHS0 Gib(v0) / Washer
Gibson GWS645RHS1 Washer - Gibson
Gibson GWS833CS0 Gibson/washer
General Electric GWSE5240H0WW Washer
Gibson GWT1149AS0 Washer - Gibson
Gibson GWT1749AS0 Washer - Gibson
Frigidaire GWT445RFS0 Gib(v0) / Washer
Frigidaire GWT445RFS1 Gib(v0) / Washer
Frigidaire GWT445RFS2 Gib(v0) / Washer
Frigidaire GWT445RGS0 Gib(v0) / Washer
Frigidaire GWT445RGS1 Gib(v0) / Washer
Frigidaire GWT445RGS2 Gib(v0) / Washer
Frigidaire GWT645RHS0 Gib(v0) / Front Load Washer
Gibson GWTR645RHS0 Gibson/washer / Front Load Washer
Frigidaire GWV19W
Frigidaire GWX223RBD1 Gib(v1) / 27 " Washer
Frigidaire GWX223RBD3 Gib(v1) / Washer
Frigidaire GWX223RBW0 Gib(v2) / 27 " Washer
  #2 (permalink)
Old 06-16-2009, 05:29 AM
Junior Member
Default summary of questions related to washer issue
To summarize, appreciate answers to the following questions.
1) any idea why clothes would slip by the outer washer plate and get jammed between the flexible gasket attached to the outer wash plate's perimeter and the stainless steel basket?
2)what direction should the flexible gasket on the outer wash plate point, down or up?
3) When trying to remove jammed clothes yesterday the felxible gasket began to tear away from the outer wash plate, it appears the outer wash plate now must be replaced as the flexible gasket is considered part of the outer wash plate...is this the case?
4) Assuming that need to replace gasket/outer wash plate does the outer wash plate offered include the rubber grommets that are recommended?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Please Help, Frigidaire Washer Door Lock Issue Damsal in Distress Washer Repair 1 05-25-2009 05:43 PM
Where can i find a Frigidaire Washer manual - overflow issue kevbayer Washer Repair 3 03-05-2009 02:15 PM
Bosch washer pump issue (already replaced pump!) wdt Washer Repair 0 12-02-2008 07:26 AM
Washer Watering Issue!!! jmambru Washer Repair 3 11-13-2008 06:13 PM
agitator issue kpt Washer Repair 0 03-05-2008 06:50 PM
