| » GE Front Load Broken Baffle Repair |
Model Number: WCVH6260 Brand: GE Age: 1 - 5 years
Just bought used Washer Dryer Set. Washer has a broken baffle.(not sure what broke it). I know that I can disassmble entirely and open the plastic tub and remove the stainless basket in order to get the screw in to the baffle. The screw hole doesn't align with the drain at the bottom (bad design as far as I'm concerned). I'm quite tempted to take the top panel off the washer and drill a hole from the inside out through the plastic tub at the top of the tub through the baffle screw hole. I could then place the screw without the huge disassembly and marinetex or silicone the drill hole closed. Any thoughts about this short-cut approach to the repair?
Related Models |
I did the repair this evening. It went very smooth. The hole is top-dead-center of the tub. Just big enough for the screw head. Used a magnetic screwdriver to place the screw. Marine silicone to close the hole. We'll see how well it holds. If problems I'll take a step up in repair materials and use an epoxy. 15 minutes vs. 2 to 3 hours the proper way.
| Display Modes | |
| No power to Whirlpool Duet front load washer after bellow repair | llm0283 | Washer Repair | 1 | 12-23-2009 01:52 PM |
| Load Thumping Noise & Unbalanced Condition On GE front load washer | Luke Vincent | Washer Repair | 2 | 08-06-2009 05:43 PM |
| Dryer Baffle Repair | sandragarrett2822 | Dryer Repair | 2 | 03-26-2009 11:02 AM |
| Kenmore top load washer has a broken lid switch | jrf | Washer Repair | 3 | 09-17-2008 01:54 PM |
| Repair manual for kKenmore front load dryer | garlut@yahoo.com | Dryer Repair | 0 | 06-18-2008 10:28 AM |
