| » washer won't drain water out |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: cam2762kqo Brand: Whirlpool Age: 5 - 10 years
at the end of the wash cycle, it does not drain the water out. The pump is okay, so is it in the motor ? board ? capasitor ? or what do you think??? oh, at that point it doesn't do anything else, then goes off and back to start.
The first thing I would check is the lid switch (#11 on the top and cabinet break down diagram). Remove the control panel, unplug the wire harness and check continuity across the lid switch terminals. It should be closed when the lid is closed.
Replace if it's open. - The part number for the lid switch is AP3020600 Gene.
__________________
Professional appliance repair services in Orange County, California. |
| Display Modes | |
| Amana washer spins but does not drain water out | fjhead2000 | Washer Repair | 2 | 11-24-2007 08:44 AM |
| Water and drain hookup | linda45302 | Dishwasher Repair | 0 | 10-09-2007 05:35 AM |
| water will not drain or spin | chefray | Washer Repair | 1 | 09-29-2007 05:02 PM |
| Water doesn't drain, spotty dishes | cherienoel | Dishwasher Repair | 1 | 09-16-2007 06:24 AM |
| Washer won't drain during spin cycle. Water Pump Belt discovered on floor | sandydjdm | Washer Repair | 1 | 08-14-2007 07:41 PM |
