Discuss
Maytag washer not filling with water completely
 in
Washer Repair
Starting yesterday, the washer began to fill with water as usual (same force) but the water shut off well before
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer not filling with water completely
  #1 (permalink)
Old 06-14-2009, 09:51 AM
Junior Member
rln57 is on a distinguished road
Default Maytag washer not filling with water completely
Model Number: LA3910   Brand: Maytag   Age: More than 10 years
Starting yesterday, the washer began to fill with water as usual (same force) but the water shut off well before the fill was complete. The same thing happened with both the hot and cold water. Any thoughts on the cause and is the washer worth fixing? I have not had any other problems with it. Thanks
Related Models
Maytag LA3910 WASHER-TOP LOADING
Whirlpool LA4000XKW0
Frigidaire LA400AXD1 Wwh(v4) / 27 " Washer
Frigidaire LA400AXD2 Wwh(v4) / 27 " Washer
Frigidaire LA400AXW1 Wwh(v3) / 27 " Washer
Frigidaire LA400AXW2 Wwh(v3) / 27 " Washer
Frigidaire LA400EXD3 Wwh(v1) / Top Loading Washer
Frigidaire LA400EXF3 Wwh(v2) / Top Loading Washer
Frigidaire LA400EXH3 Wwh(v3) / Top Loading Washer
Frigidaire LA400EXV3 Wwh(v4) / Top Loading Washer
Frigidaire LA400EXW3 Wwh(v5) / Top Loading Washer
Frigidaire LA400JXD3 Wwh(v1) / Washer
Frigidaire LA400JXD4 Wwh(v1) / Top Load Washer
Frigidaire LA400JXF3 Wwh(v2) / Washer
Frigidaire LA400JXF4 Wwh(v2) / Top Load Washer
Frigidaire LA400JXH3 Wwh(v3) / Washer
Frigidaire LA400JXH4 Wwh(v3) / Top Load Washer
Frigidaire LA400JXH5 Wwh(v2) / Top Load Washer
Frigidaire LA400JXV3 Wwh(v4) / Washer
Frigidaire LA400JXV4 Wwh(v4) / Top Load Washer
Frigidaire LA400JXW3 Wwh(v5) / Washer
Frigidaire LA400JXW4 Wwh(v5) / Top Load Washer
Frigidaire LA400JXW5 Wwh(v1) / Top Load Washer
Frigidaire LA400MXD1 Wwh(v6) / 27 " Washer
Frigidaire LA400MXD2 Wwh(v8) / 27 " Washer
Frigidaire LA400MXH2 Wwh(v9) / 27 " Washer
Frigidaire LA400MXW1 Wwh(v5) / 27 " Washer
Frigidaire LA400MXW2 Wwh(v7) / 27 " Washer
Maytag LA410 WASHER-TOP LOADING
Maytag LA412 WASHER-TOP LOADING
Frigidaire LA415LXD1 Wwh(v4) / Top Load Washer
Frigidaire LA415LXW1 Wwh(v3) / Top Load Washer
Whirlpool LA4400XSW0
Frigidaire LA444MXD1 Wwh(v4) / 27 " Washer
Frigidaire LA444MXW1 Wwh(v2) / 27 " Washer
Frigidaire LA450AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA450AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA450AXD3 Wwh(v1) / 27 " Washer
Frigidaire LA450AXH2 Wwh(v3) / 27 " Washer
Frigidaire LA450AXH3 Wwh(v2) / 27 " Washer
Frigidaire LA450AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA450AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA450AXW3 Wwh(v3) / 27 " Washer
Frigidaire LA450JXD3 Wwh(v6) / Washer
Frigidaire LA450JXD4 Wwh(v6) / Top Load Washer
Frigidaire LA450JXD5 Wwh(v4) / Top Load Washer
Frigidaire LA450JXF3 Wwh(v7) / Washer
Frigidaire LA450JXF4 Wwh(v7) / Top Load Washer
Frigidaire LA450JXH3 Wwh(v8) / Washer
Frigidaire LA450JXH4 Wwh(v8) / Top Load Washer
Frigidaire LA450JXV3 Wwh(v9) / Washer
Frigidaire LA450JXV4 Wwh(v9) / Top Load Washer
Frigidaire LA450JXW3 Wwh(v10) / Washer
Frigidaire LA450JXW4 Wwh(v10) / Top Load Washer
Frigidaire LA450JXW5 Wwh(v6) / Top Load Washer
Frigidaire LA450MXD1 Wwh(v4) / 27 " Washer
Frigidaire LA450MXD2 Wwh(v5) / 27 " Washer
Frigidaire LA450MXH2 Wwh(v6) / 27 " Washer
Frigidaire LA450MXW1 Wwh(v3) / 27 " Washer
Frigidaire LA450MXW2 Wwh(v4) / 27 " Washer
Frigidaire LA470AXD1 Wwh(v2) / 27 " Washer
Frigidaire LA470AXW1 Wwh(v1) / 27 " Washer
Frigidaire LA470BXD1 Wwh(v2) / 27 " Washer
Frigidaire LA470BXD2 Wwh(v2) / 27 " Washer
Frigidaire LA470BXW1 Wwh(v1) / 27 " Washer
Frigidaire LA470BXW2 Wwh(v1) / 27 " Washer
Frigidaire LA470LXD1 Wwh(v1) / Top Load Washer
Frigidaire LA470LXW1 Wwh(v2) / Top Load Washer
Frigidaire LA470MXD1 Wwh(v2) / 27 " Washer
Frigidaire LA470MXD2 Wwh(v2) / 27 " Washer
Frigidaire LA470MXH2 Wwh(v3) / 27 " Washer
Frigidaire LA470MXW1 Wwh(v1) / 27 " Washer
Frigidaire LA470MXW2 Wwh(v1) / 27 " Washer
Whirlpool LA4800XSW0
Whirlpool LA4800XTF0
Whirlpool LA4800XTF1
Whirlpool LA4800XTG0
Whirlpool LA4800XTG1
Whirlpool LA4800XTM0
Whirlpool LA4800XTM1
Whirlpool LA4800XTN0
Whirlpool LA4800XTN1
Whirlpool LA4800XTW0
Whirlpool LA4800XTW1
Maytag LA482 WASHER-TOP LOADING
Maytag LA484 WASHER-TOP LOADING
Maytag LA490 WASHER-TOP LOADING
Frigidaire LA490AXD1 Wwh(v4) / 27 " Washer
Frigidaire LA490AXW1 Wwh(v3) / 27 " Washer
Maytag LA4910 WASHER-TOP LOADING
Maytag LA5000 WASHER-TOP LOADING
Whirlpool LA5000XMW0
Whirlpool LA5000XPW0
Whirlpool LA5000XPW1
Whirlpool LA5000XPW2
Whirlpool LA5000XPW3
Whirlpool LA5000XPW4
Whirlpool LA5000XPW5
Whirlpool LA5000XSW0
Whirlpool LA5000XSW1
Frigidaire LA500AXD5 Wwh(v2) / 27 " Washer
Frigidaire LA500AXD6 Wwh(v2) / 27 " Washer
Frigidaire LA500AXW5 Wwh(v1) / 27 " Washer
Frigidaire LA500AXW6 Wwh(v1) / 27 " Washer
Frigidaire LA500EXD3 Wwh(v6) / Top Loading Washer
Frigidaire LA500EXF3 Wwh(v7) / Top Loading Washer
Frigidaire LA500EXH3 Wwh(v8) / Top Loading Washer
Frigidaire LA500EXV3 Wwh(v9) / Top Loading Washer
Frigidaire LA500EXW3 Wwh(v10) / Top Loading Washer
Frigidaire LA500JXD3 Wwh(v11) / Washer
Frigidaire LA500JXD4 Wwh(v11) / Top Load Washer
Frigidaire LA500JXD5 Wwh(v7) / Top Load Washer
Frigidaire LA500JXF3 Wwh(v12) / Washer
Frigidaire LA500JXF4 Wwh(v12) / Top Load Washer
Frigidaire LA500JXH3 Wwh(v13) / Washer
Frigidaire LA500JXH4 Wwh(v13) / Top Load Washer
Frigidaire LA500JXH5 Wwh(v8) / Top Load Washer
Frigidaire LA500JXV3 Wwh(v14) / Washer
Frigidaire LA500JXV4 Wwh(v14) / Top Load Washer
Frigidaire LA500JXW3 Wwh(v15) / Washer
  #2 (permalink)
Old 06-15-2009, 05:56 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
The likely culprit here is your water level switch. I think your machine as a variable level of control, and the switch may be stuck at a low level.
Try moving the switch up and down a couple of times to see if that will loosen it up, then start the machine several times with no clothes and see if you get different water levels with different settings.
If not and you are happy with the machine (these are pretty good ones) you could risk the small amount of money changing out the water level switch.
Good luck, it will be interesting to find out how this works out so please post what you find out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tub Not Filling Completely - Pump Growling Raredude Dishwasher Repair 2 05-22-2010 06:11 AM
Maytag washer overflows with water when filling MIKE HARMON Washer Repair 1 02-03-2010 01:39 PM
Maytag Washer Won't Stop Filling rinmarie2002 Washer Repair 1 12-22-2009 05:24 PM
Estate washer wont drain water completely redcyclone11 Washer Repair 3 04-27-2009 06:42 AM
Maytag Neptune won't extract water completely letsal Dishwasher Repair 3 05-19-2008 12:23 PM
