Discuss
frigidaire washing machine
 in
Washer Repair
My daughter pulled on the door when it was in lock and the handle busted off.. Every since, it won't
Appliance Repair Forum > Appliance Repair Help > Washer Repair » frigidaire washing machine
  #1 (permalink)
Old 06-12-2009, 06:28 PM
Junior Member
kimjkenyon is on a distinguished road
Default frigidaire washing machine
Brand: Frigidaire   Age: Less than 1 year
My daughter pulled on the door when it was in lock and the handle busted off.. Every since, it won't go threw a whole cycle... Sometimes it will release water and sometimes it won't (when it's suppost to) and then it won't spin out the clothes... I tried every cycle and it takes me about 10 washes on different cycles just to get a load washed and spun out... I figure it's some kind of sensor in the handle or something. Just trying to figure out what part to replace? The whole door? a new handle or something totally different like a sensor panel????
Ads By Google
  #2 (permalink)
Old 06-14-2009, 04:32 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Kim
Without a model number I can only make an educated(?) guess that the door lock mechanism has been damaged. If it is locking and unlocking this could be sending signals to your control board and causing your problems.
I would try to see if you can get this fixed under warranty, and if not and you want to go after it, post a model number and let's see if we can be of any help. Unfortunately, the newer the machine the less we know about it (now if you had a nice 10 year old washer we could be of great service)
Good luck, hope it turns out well.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire washing machine monicaowen Washer Repair 1 09-30-2009 07:46 AM
frigidaire washing machine top load jason241 Washer Repair 1 07-19-2009 04:44 PM
Frigidaire Top Loading Washing Machine not Spinning truett Washer Repair 5 07-08-2009 07:47 AM
Trunion stuck on Frigidaire FWXB23RGS0 Washing Machine jdsuowner Washer Repair 2 04-05-2009 06:06 PM
Frigidaire washing machine vibrations sundevil99833 Washer Repair 0 09-07-2007 11:22 AM
