i replaced the pump assembly about 1 yr ago, and now am getting LD code no lint build up, no kinks in hoses, nothing under washer plate, i did find a penny down in the bottom near the ball, maybe that is the cause? or could the water level switch be fooling the machine?
If you are sure there is no obstruction, and the pump is working and the water is being drained then the water pressure switch is the likely culprit.
I would replace it and see if that fixes it. Let us know how it turns out.
Also, I think the g in your model number is a q.
Good luck
